Hiking Boot Gaiters_v2
Introduction: Hiking Boot Gaiters_v2
These lightweight gaiters are designed to keep rocks, stickers, seeds, and other debris out of your hiking boots. They are made to fit mid-height boots and work best on boots with padded collars at the top. I use these primarily for hiking in the deserts of the southwestern U.S., so I don't worry about waterproofing.
Materials
Fabric, two pieces 18 inch by 8 inch each
Rug gripper (also sold as drawer liner), two pieces 1-1/2 inch wide about 14 inch long
Round elastic cord, 1/16 inch diameter, two pieces 16 inch long
Round elastic cord, 1/8 inch diameter, two pieces 16 inch long
Four mini cord locks
Thread
Tools
Tape measure
Scissors
Marker
Sewing machine
Step 1: Cut Fabric and Hem
Cut two pieces of fabric 18 inch by 8 inch each. I like using ripstop nylon for durability, 1.1 to 1.9 ounce per square yard is fine. But you can use almost any fabric for this project; even old pant legs, bed sheets, shower curtains, whatever you have on hand.
Hem long edges of each piece about 1/4 to 3/8 inch from edge, then hem the short edges.
Fold the short edges again and hem about 1/2 inch from edge. This second hem encloses the cut edge of the fabric to prevent the edge from becoming frayed.
Step 2: Fold Corners
Fold each corner at 45 degrees about 1 inch and stitch in place.
Step 3: Form Cord Sleeves
Fold top long edge about 1/2 inch and straight stitch along long edge to form a sleeve or tube for the elastic cord. Fold bottom edge about 1-1/2 inch and straight stitch along edge to form a sleeve for the bottom elastic cord.
Step 4: Stitch Gripper in Place
Cut two pieces of rug gripper, 1-1/2 inch by 14 inch. Center on inside along bottom edge, stitch close to bottom edge using narrow zig zag stitch. You may need to reduce presser foot pressure. Be careful not to sew across ends of cord sleeve. Stitch close to the top edge of gripper using a wide zig zag stitch. The gripper may stretch some, trim off excess.
Step 5: Stitch Short Edges Together
Fold the gaiter, gripper side out (inside out), so short edges are together. Straight stitch short edges together being careful not to stitch across the cord sleeves.
Turn gaiter right side out.
Step 6: Top Elastic Cords
Cut two pieces of 1/16 inch diameter elastic cord, 16 inch long each. Singe cord ends in a flame to seal.
Use a small safety pin to thread the elastic cord through the sleeve at the top of each gaiter.
Pull the cord ends through a mini cord lock and tie an overhand knot at each cord end.
Step 7: Bottom Elastic Cords
Cut two pieces of 1/8 inch diameter elastic cord, 16 inch long each. Singe cord ends in a flame to seal.
Use a small safety pin to thread the elastic cord through the sleeve at the bottom of each gaiter.
Step 8: Wearing the Gaiters
Put on socks. Then pull the gaiter on over your sock, gripper end down. Put on boots, lace, and tie. Pull gripper end down over the top of boot, tighten bottom elastic cord until it is snug. Pull top elastic draw cord ends to close the top edge around your leg above the top of the boot, just tight enough to keep the top closed around your leg.
Be the First to Share
    • Exercise Speed Challenge
    • Pocket-Sized Speed Challenge
    • Super-Size Speed Challenge
