Hobbit Christmas Sign
Introduction: Hobbit Christmas Sign
About: Crafting tales about the things I make at my workbench 🛠🧰
On the sixth day of Christmas my true love gave to me - a Hobbit welcome sign! Or unwelcome sign, depending on the kind of business your bringing. But remember:
Christmas business only!
Here's how I put this project together:
Supplies:
Materials I used: (with affiliate links)
1/2" 6"x24" pine board
Vinyl - https://amzn.to/2rwGlje
Transfer paper - https://amzn.to/2Ed37iQ
Chalk paint - https://amzn.to/36Fdw31
Nails - https://amzn.to/2PCU0x7
Craft wire - https://amzn.to/2EebpH6
Small screws
Danish oil - https://amzn.to/2YPhmUf
Tools I used:
Brother plotter - https://amzn.to/36qkFnm
Weeding hook - https://amzn.to/38AGORM
Hammer - https://amzn.to/2PDUsLA
Squeegee - https://amzn.to/2YIvvTb
Sponge
Teacher Notes
Step 1: Design the Sign
The first thing I needed to do was to go and find a font that fit the sign from the Hobbit. I found one called 'hobbiton' and downloaded and installed it. The font doesn't exactly match the sign from the Hobbit, but it was close enough.
I measured my board, and matched the dimensions in Illustrator, then type out my Hobbit message (adding in Christmas). Sizing it to the size I wanted, I centered it on the board and sent the file to my plotter.
Step 2: Cut the Stencil
Using the plotter software, I adjusted the message to fit corner to corner on the vinyl so ensure it was big enough for the board. I then cut it out on the plotter.
Using a weeding hook I removed all the lettering, then placed the transfer paper over the vinyl. After squeegeeing (that a word, right?) the transfer paper down I cut around the lettering.
Step 3: Placing the Stencil
I peeled the stencil off the backing and placed it on the board. I squeegeed the stencil evenly across the board, then removed the transfer paper.
Step 4: Paint
Cutting up a small piece of sponge, I used it to dab the chalk paint onto the stencil. I let it dry, then applied another layer of paint, trying to get as even of coverage as possible.
While the paint was ever-so-slightly still wet, I started peeling the vinyl off the board (I did this to ensure that any dry paint wouldn't peel off with the stencil). I used the weeding hook to help get the smaller pieces of vinyl
Step 5: Cutting to Size
Based on my stencil, I realized that I needed to cut my sign down a few inches to match the reference sign from the Hobbit. I made a mark on the sign, squared a line, then cut to size.
Step 6: It's Hammer Time
I took some nails that I had and cut them to size. Making 4 marks on the board that matched the placement of the nails from the sign in the Hobbit, I hammered the nails the nails into place.
Step 7: Oil and Hang
Using another piece of sponge, I took some danish oil and oiled down the entire sign. I screwed 2 small screws into the back of the sign, then wrapped some craft wire around each to make it hang-able.
Step 8: Print a Mount Hook
I wanted to mount this sign on the Candy Cane post I made, so I 3D printed a mounting hook (the same one I used to mount in the Excitebike bike shed)
Using 1 1/2" screws, I mounted the hook to the front of the candy cane post, then hung the sign
Step 9: Welcome Guests... or Unwelcome Them
Now that the sign was proudly hung, I could welcome guests in geeky style. Or unwelcome them. It would depend on the type of business. But please, just remember:
Step 10: Watch the Video!
Now that you know how it was put together, watch it being done!
I have more geeky projects you can check out here on Instructables, so be sure to follow me for when I put out new Instructables
AND you can watch more of my project videos here
AND you can also follow me on Instagram @onceuponaworkbench
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Wearables Contest
      Wearables Contest
    2 Discussions
    audreyobscura
    audreyobscura
    6 weeks ago
    This came out great! Consider entering it into the Home Decor Challenge!
    OnceUponaWorkbench
    OnceUponaWorkbench
    Reply 6 weeks ago
    The what with what what? I need to go find that...
