DIY Home Automation - ThiDom
Introduction: DIY Home Automation - ThiDom
ThiDom is a Home Automation solution devloped by myself.
Based on Raspberry Pi who is the core of system ( Web interface, manage scenario, planning ...).
The home automation modules communicate in 2.4Ghz with NRF24L01.
Step 1: Parts Required
For this project we will be requiring
Hardware:
* Raspberry Pi
* Arduino Uno
* NRF24L01+
* NRF24L01+ LNA + PA
* Attiny84
* Temperatur sensor
* relays
Software:
* ThiDom
Step 2: Building Master Device
To build master device you need :
Raspberry
Arduino Uno
NRF24L01+ or NRF24L01 + PA + LNA
Step 3: Build a Node
This node allow to manage a relay.
To build you need :
1 Regulator HLKPM01 ( 230V -> 5V)
1 Regulator TLV1117 (5V -> 3V)
2 Capacitores 1µf ( C1206C105J5RACTU ) One in input of TLV11171 and one in output of TLV11171
1 Attiny84
1 NRF24L01
1 Capacitor 4.7µF ( between 3V and GND of NRF24L01 ) ( C1206C475J3RACAUTO )
3 headers strip to temperature sensor
1 resistor 4,7 kohms ( CRG1206F4K7 )
1 relays ( T77S1D10-05 )
1 NPN to activare relays ( SST2222AT116 )
1 resistor 3.3 Kohms to NPN ( CRG1206F3k3 )
1 resistor 40 Mohms ( sensitif interrupt ) ( RH73H2A40MKTN )
1 fuse 800mA ( 0464.800DR )
1 varistor( V275LA20AP )
With this node you can manage thermostat, light and get temperature data
Step 4: Example of Topology NRF24L01
Step 5: Website Interface
With the website interface, you can :
* manage your device ( add, delete, hide, show ...)
* make action on each devices( light, thermostat ..)
* See each value of devices
* See history data ( graph, log )
* Manage Scenario
* Manage Planning
Step 6: Demo Acces
You can try ThiDom, follow link Demo Acces (The actions will not be considered so there will be no visual change)
And follow on Twitter and on the blog
IoT Challenge
IoT Challenge
Be the First to Share
    • Puzzles Speed Challenge
    • "Can't Touch This" Family Contest
    • CNC Contest 2020
      CNC Contest 2020
