Home Automation Using NodeMCU | Iot Projects | Firebase | Nodemcu Esp8266
About: This is Electronic Project Forum which aims to help new members to build easy D I Y ( Do It Yourself ) Electronic Projects
This video tutorial is SPONSORED by JLCPCB.Com They are providing a quality PCB's for Under 2$ Only first register from the link below and Upload your Gerber file / Eagle design That's it....
►► https://jlcpcb.com/
Today in this video tutorial i am going to show you Step By Step
How to make smart home automation control system using nodemcu esp8266 and firebase database internet of thing Iot relay
―――――――――――――――――――――――――――――――――――――――――― ❖ Please Subscribe / Like Facebook Page ❖ ――――――――――――――――――――――――――――――――――――――――――
https://www.youtube.com/channel/UCi6ZqREHDIx2xLrCRkrRS0w
https://www.facebook.com/Circuit-DIY-122206971927665
Download All Data Files ► https://www.file-up.org/nw33aap9oi8e
You Will Find Full Project Description and All Useful Material Including
  • • Circuit Diagram / Schematic
  • • Hardware / Component List
  • • Code
  • • Datasheet
  • • Pin Configuration Etc
AT ► Thanks for Watching It.
↪ For Any Difficulty Please Comment Below
Step 1: Hardware Required
  • ► PCB Smart Home Automation
  • ► Node MCU ESP8266
  • ► 5v Relay 4x
  • ► 1N4006 Dideos 4x
  • ► 330 Ohm Resistors 5x
  • ► BC547 Transistor NPN
  • ► 5mm Terminal Block 4x
  • ► 5v Regulator
  • ► Power LED
  • ► DC Power Jack
Step 2: Steps
Follow All Steps Carefully from the Video Above
STEP # 1 ( Solder All Components )
STEP # 2 ( SettingUp Aruino IDE )
► Download given library and include it in arduino ide
STEP # 3 ( SettingUp Firebase )
► Login to firebase add project copy database url and authentication code and update to arduino code
STEP # 4 ( Make App from MIT App Inventor2 )
► Make changes to the app by importing ai file and update URL and Authentication code here too
STEP # 5 ( Let's Try )
    • Pie Contest
      Pie Contest
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest
      Paper Contest
