Home Made Induction Cooker
2,650
19
10
On my this channel you will find many types of electrical, electronics or other techno-type proje...
Make a very convenient and robust induction heater at home by watching this video
Teacher Notes
Step 1: Frame Construction
Make a frame according the top plate size or as you think convenient.
Step 2: Frame Construction
After measuring the center make a horizontal plane to lay the coil on it.
Step 3: Parts Fitting
Make appropriate fitting stands for the motherboard and cooling fan. Make sure the cooling fan must be above the heat sink of the motherboard and beneath the coil.
Step 4: Front and Outer Finish
For finishing and good looking stick sun-mica on it and make an appropriate cut for control panel in front side.
Step 5: Fitting All the Parts
Now fit all the parts and tight them with the screws. Also connect all the sockets and main lead to power supply.
Step 6: Finishing With Top Glass
Now adhere the top glass with a little quantity of fevicol. Remember that the surface of all four borders should not be covered by the top glass. Make some space for ventilation between top glass and the border surfaces.
Step 7: Done
Now a home made induction heater is ready to use.
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
    10 Discussions
    dhaykus0418
    Question 9 months ago
    Links to the parts you bought? I don't have a cooker to salvage, are coils available for U.S. voltage?
    ansmanndhaykus0418
    Reply 9 months ago
    Sorry dear, all the parts I used in this induction cooker are easily available in our local market and are according to India Voltage. You should try in your market for the parts you need for.
    MuriloC7ansmann
    Reply 9 months ago
    what is the name of the components used so we can search?
    ansmannMuriloC7
    Reply 9 months ago
    1. Mother Board. It comes with control unit.
    2. Induction Coil;
    3. Induction Fan;
    4. Top Glass or Plate
    5. Power Cable.
    acheide
    Are you planning to show details of the the electronics? Did you buy or build them? Are they the original electronics?
    ansmannacheide
    Reply 9 months ago
    Of course I will show the detail in some next video. Please wait.
    ...Thanks
    ansmannacheide
    Reply 9 months ago
    Most of the internal parts are bought from market. But the housing is completely made by me. Of course in some of my next video I will show the complete detail of its wiring step wise. Then you should visit my YouTube channel: https://www.youtube.com/SatyamTechTricks
    tercero
    9 months ago
    Not much of an ible really. More like this is what I built.
