Home Security System Using PIR Sensor With IoT
Hello Friends, This is Anto.. In this tutorial, we are going to learn how to make a simple home security system using the blynk app
Supplies:
I strongly suggest you to buy the components from UTSource.net. because in my experience, the quality of the products are good. and also ON TIME Delivery. If you need quality PCB, they will afford at low cost from double side to multilayer. No minimum requirement.
Materials Required:-
ESP 8266-01
PIR Sensor
ESP Breakout board
USB to TTL Converter
Teacher Notes
Step 1: Login the Blynk App and Create the Project
Login with your email id and password
click new project
give a suitable name and select esp8266
click create
select the Add button on the top and click notification to place it on the screen
Step 2: Add the Blink Library to the Arduino IDE
In order to add the blynk library to the arduino IDE, i have given the full explanation on my another article..
https://www.instructables.com/id/Home-Automation-U...
please follow that and add the blynk library to the arduino IDE
Step 3: Copy the Token From Your Email and Paste It on the Attached Code
The program code is on the attachment, Download the code and open the code using arduino IDE, copy the token from your email and replace it on the code. download the code to the esp module using USB to TTL converter.
Step 4: Connect the Out of the PIR Sensor to the GPIO0 of the ESP
connect the OUT of the PIR sensor to the GPIO0 of the ESP module. so that the ESP will read the status of the PIR sensor...
connect +5v to the VCC of the PIR sensor and connect the GND to the GND.
Step 5: Run the Blynk App and Check the Notification
Run The Blynk App...
switch ON the hardware
Show some movement infront of the PIR sensor with your hand.
verify the the POP UP notification on the screen of the Mobile..
Enjoy............
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
