Home-made Gumball Machine
Introduction: Home-made Gumball Machine
Here is a home made gumball machine that uses 1/2 inch gumballs
Teacher Notes
Step 1: Creating the Handle
First I had to create the handle and the axle for the gumball mechanism for the gumball machine
Step 2: Quarter Slide
I created this piece make a place for the quarter to rotate in while you turn the handle
Step 3: Front of Quarter Mechanism
This is the piece where you have to put in the quarter when you order a gumball
Step 4: Coin Holder
This is the piece that holds the coin while it goes inside the two pieces witch is controlled by the handle's axle
Step 5: Axle Protection
I added this piece to the axle to create less force on the wood and the axle
Step 6: Gumball Gear
This piece is attached to the axle to create the motion in the next gear to move the gumballs around the machine
Step 7: The Gumball Mover
This piece moves the gumballs from the pickle jar to the slide to the person
Step 8: Gear Holder
This piece holds the gumball gear to hold it and also lets it spin this piece also holds the pickle jar that holds all the gumballs
Step 9: Pickle Jar
This piece holds all the gumballs
Step 10: Gumball Slide
This piece was used to transfer the gumball from the gear to the person
Step 11: Bottom of Gumball Machine
This piece holds all the wood still from the bottom of the machine
Step 12: Instructions
Here is all the instructions to recreate your very own gumball machine
Be the First to Share
    • Trash to Treasure Contest
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
