Introduction: Homemade CO2 Pump to Planted Aquariums
The present presentation is going to describe the steps required to
stablish the proper conditions to produce natural CO2 with basic and cheap
materials. This is a topic of interest to those people that enjoy having
healthy aquatic plants whether it is for decoration or hobby. For those who
don’t know anything about how to keep up aquariums, I can clarify that it doesn’t affect
the domestic fishes at all, instead, it can bring positive benefits to your
life and I want to share that to you from my personal point of view.
It is very important to plan it before starting out so we have the materials, the tools, the time,
the location and the logistic to achieve it successfully minimizing any difficulties that ruin our
experience while working.
Step 1: Project Cost
This is a very easy project not only because it doesn’t require any kind
of deep knowledge about chemistry and physics, but because most of the items to
make it we already have or are replaceable depending on our own mental skills
and invention. The total cost of it buying all the items is $80.00. If
you don’t have the money don’t discourage yourself, just try to understand what
the project is about, and you will see that practically everything on it can be
made with homemade or recycled materials, is your challenge to personalized it and
make up new things.
Step 2: Materials
The materials
that are going to be needed are:
1.
2 Liters Bottle; for free or $2.00 max.
2.
Regular Syringe $1.00
3.
Airline Tubing (any pet store); $6.00
4.
All-Glass Aquarium Silicone Aquarium Sealant
(pet store); $9.00
5.
Super glue; $6.00 to $10.00
6.
Sugar (brown sugar works too); $3.00
7.
Yeast; $5.00
8.
Sponge; $6.00
9.
Aquarium gravel; 6.00
10.
Fish carrier or small container; $6.00
11.
Aquarium air valve (any pet store); $1.00
12.
Aquatic plant (any pet store); $?
Step 3: Tools
The tools that
1.
Star screwdriver; $7.00
2.
Pliers; $10.00
3.
Lighter; $3.00
4.
Funnel; $2.00
5.
Scissors; $3.00
Step 4: 1. Making the Drop Counter
We will pull back-off completely from the syringe the plunger, then we
insert the tubing in the back of the barrel and seal it with the silicone, it
is very important to make sure that the air only flow into the barrel through
the tubing and the mouth.
After the silicone is all dry, the next step is opening a hole right in
the middle of the bottle’s cap with the screwdriver, the lid is supposed to be
very fragile so preheat the end of the screwdriver with the lighter until it is
hot enough to go straight through the plastic cap with no problem. The hole
should be big enough so we can plug in the mouth of syringe through without
forcing it. Then after both the cap and the syringe fit perfectly, we proceed
to glue them with glue, first which dries faster and then sealing it with
silicone. It is very important not having any escapes, otherwise all this this
work is going to be useless.
Step 5: 2. Marking and Filling Up the Bottle:
We mark our bottle with two different spots, one at the bottom for the
sugar, one in the middle where hot water should reach up to dissolve the sugar,
and finally the rest the bottle has to be filled with yeast dissolved cold
water. If you find yourself in problems to make the substances go through the
mouth of the bottle, use a funnel, which might result helpful. Normally after
preparing the mix, it is going to take about one hour for the yeast to start metabolizing
the sugar resulting in CO2.
Step 6: 3. Adding the Valve to the Drop Counter
We use the scissors or pliers to cut the tubing 2 inches away from the syringe, then we
introduce one of the cavities of the valve into the tubing connected to the
syringe. The other extremity of the valve is going to be connected to the
tubing that contact feed the recipient.
Step 7: 4. Attaching the Dropper to the Tubing
The end of the tubing that is going to feed the recipient should not be
left without something called diffuser, which is going to make the CO2 bubbles
a lot smaller and easier to be caught by the plants. For that task we pull the
cork off of the dropper, itself hole just uncovered is going to be the hole
exposed with the water, the other end which is the narrow one should be
impregnated with super glue and inserted into the tubing as deep as possible
without breaking it.
The next is to reap of a peace of the sponge and introduce it with
pressure into the “ex” dropper.
Attaching the tubing to the recipient is a lot easier to one of the corners of the it
than in another place, however you can do it wherever you want. Use super glue
which dries out faster than silicone.
Step 8: 7. Charging Up the Drop Counter
This instrument is made to have water inside so we can see the bubbles
climbing through it, if there are not bubbles it means that the CO2 production
is over. To fill up the drop counter we need to have the valve open (free air
flow) and connected to it, then what we do is to submerged the cap of the
bottle (Attached to the syringe) into water; once we do it we hold the valve
with our mouth to suction water while we twist knob to close it and stop the
air-water flow. Magically the won’t come out of the drop counter unless we open
the valve knob.
Step 9: Final
After following all these steps our project is going to be completed and
ready to go, the CO2 production is going to last about 1 week, after that we can dump out the old mix and
prepare a new one so our plants stay nice and healthy.
