Homemade Clamp From PVC Pipe
4,970
45
14
Hello!
Clamp, it's a cheap tool. A few pieces are enough to always be at hand. But if a large number of Clamps are required, then the cost grows significantly. It is good that you can make a clamp with your own hands. The model is simple to manufacture and easy to operate. To make the clamp you will need a piece of PVC pipe. The thicker the walls, the greater the compression ratio.
Teacher Notes
Step 1:
1. You need to cut the pipe lengthwise
Step 2:
2. Attach the handles and mark where the entry holes will be.
Step 3:
3. Mark where there will be exit holes for handles.
Step 4:
4. Then take the drill to the size of our handles. I have a handles 10 mm.
Step 5:
5.Stainless steel fully threaded stud 1m cut into 4 parts
Step 6:
6. Using a screwdriver, screw the stud into the holes
Step 7:
7, I marked the holes for the handles so that I could use the clamp with one hand
Step 8:
8. The grip force of the small clamp from the store.
Step 9:
9. The grip force of my clamp
Step 10:
Our clamp is ready. Thus it is possible to make clips and longer.
Hope you like my DIY.
Best whishes !
Make it Move
This is an entry in the
Make it Move
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    14 Discussions
    discostu956
    2 days ago
    Love the simplicity of this!
    dwieland
    4 days ago
    This is a clever use for vent pipe offcuts (leftover pieces), and I suspect that ABS drain pipe could work too. Stainless steel threaded rod is expensive in Canada, but I don't see why a cheaper rod wouldn't work as well. A design variation that could increase the clamping range (both thickness and force) is to add a long bolt across the diameter that could be tightened to pull the jaws tighter.
    Polkilodwieland
    Reply 4 days ago
    Oh! Thats brilliant idea :)! That's will be clamp 2.0:) thats will upgrade in to next level! :)
    Yonatan24
    4 days ago
    I can't watch the video, you need to go in the video settings and change it so Youtube allows embedding BTW.
    PolkiloYonatan24
    Reply 4 days ago
    Please try one more time. I changed settings.
    rnjenny
    6 days ago
    pretty nifty!
    seamster
    6 days ago
    Very nice, and I love the simplicity!
    If I make a few, I might put a couple layers of heat-shrink tubing on the outside rod ends to make them more comfortable.
    Polkiloseamster
    Reply 6 days ago
    Thank you! Im glad you like it! :)
