Homemade Desk Organizer
A great way to keep pens, pencils and, erasers on a desk.
Supplies:
  • hot glue gun
  • rope
  • ruler/measuring tape
  • hinge
  • paper
  • drill
  • pencil
  • scissors
  • wood
Teacher Notes
Step 1: Measure You Wood
you need to measure your wood so you have two 11" by 7" rectangles drawn out
Step 2: Cut Your Wood
you need to cut out your rectangles, i'm using a scroll saw but you can you what ever you want. make sure you wear safety glasses. sand it at the end.
Step 3: Putting on the Hinge
flip your two pieces so that the ends are together. your hinges will go right where they meet. you need to mark the holes and then drill the holes. make sure you wear your googles. now line up the hinge again so you can screw it in.
Step 4: Add the Rope
warm up the hot glue gun. you need to cut two pieces of rope that are 6" each. unfold it and line up the ropes. put a big glob of glue. do the same to the other side
Step 5: Make Your Pouches
take a square piece of paper and fold it into a triangle, next fold the two corners up. unfold and fold on layer of the top down, fold one corner back up and fold the top of it into the pocket do the same to the other side. repeat 5 more times
Step 6: Putting the Poches On
put a dot of hot glue on the top and push it on the top left corner repeat for all of the poches
Step 7: (optional) Clip
take any clip and glue it on the back
Step 8: Your Done
Classroom Organization Challenge
This is an entry in the
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
