Materials:
Solid steel bar 3cm x 8 mm
1 piece 35cm x8mm
2 pieces 17cm x 8 mm
1 piece 12 cm x 8mm
2 pieces 14.5 cm x 8mm
1 piece 9,5 cm x 8mm
2 pieces 2cm x 8mm
1 piece 25cm M16 rod and 9 nuts m16
round rube 25m and 2 pieces 45 mm x 5mm
Teacher Notes
Step 1: Cut the Pieces
Cut all pieces of solid steel bar
Step 2: Give It Shape
Weld all the pieces step by step as in the video.
Step 3: Nuts
Weld 2 nut in middle solid steel bar.
Step 4: Rod
weld one nut on top of m16 rod and give it round shape. Next cut the pipe and 38 mm x 4 mm round piece and weld it on rod .
Step 5: Handle
Weld 7 nuts or more if you like with spots .
Step 6: Paint
Paint first with primer and the with your favorite color.
Step 7: Its Done
Now you have a heavy duty F clamp.
First Time Author Contest
19 days ago
This clamp does not mess around!
