Homemade Hot Pack
  • Please read all instructions before beginning.
  • Gloves are recommended, but not required. They are used to keep hands clean when using scented oils.
Teacher Notes
Step 1: Gather Supplies
Your needed supplies will include a bag of rice, a measuring cup, a sock, ziplock bags, scented oils, and gloves.
Step 2: Put on Gloves
Put on gloves to prevent scented oils from getting in your hands. Note that this step is optional.
Step 3: Scoop Out Rice
Scoop rice out of bag using measuring cup. Scoop about 1 cup.
Step 4: Pour Rice in Sock
Pour the rice into the hole of the sock. As seen in the picture, pull the hole of the sock over and then pour.
Step 5: Repeat the Process
Repeat steps 3 and 4 about 3-4 more times to fill the sock with rice.
Step 6: Compact Rice in Sock
Squeeze the rice down the sock, starting from the end with the hole. This will compact the rice into the sock to make the hot pack larger.
Step 7: Select Scent
Select an oil scent to use in the hot pack.
Step 8: Open Sock Hole
Widen the hole in the sock to make adding scent easier.
Step 9: Add Scent to Hot Pack
While you have the hole widened, pour several drop into the hole of the sock. 5-8 drops is recommended, however you can add more to increas the strength of the scent.
Step 10: Tie the Knot
Tie the end of the sock with the hole into a knot.
Step 11: Bag It Up
Keep hot pack stored in a ziplock bag to help make the scent last longer.
Step 12: Complete!
Your Homemade Hot Pack is not complete!
Be the First to Share
    • Book Character Costume Challenge
    • Made with Math Contest
    • Cardboard Speed Challenge
