Introduction: Homemade Mill CNC Router Laser Milling Plotter Frame DIY Z Axis Linear Motion Actuators 3D Printer
About: DIY Thingiverse 3D Printer Machine
Step 1: Materials
2 pcs 8 mm x 120 mm linear shaft 3d printer Cylinder Liner Rail Linear Shaft
2 pcs Ball bearing Linear Bearing LM8UU for 3D Printer Parts Accessories
1 Nema 17 Stepper Motor 17HS8401,1.8A,4.8kg.cm Holding Torque,5mm Diameter Shaft
Step 2: Hardware
2 pcs 2040 Aluminum Extrusion Profile European Standard 120 mm
1 pcs Spindle DC 12-24V 775 Miniature Mini Motor Machine
1 pcs 5x8mm CNC Motor Jaw Shaft Coupler 5mm To 8mm Flexible Coupling OD 19x25mm
1 pcs 3D Printer T8 screw TrapezoidalLead Screw Dia 8MM Lead 4 mm Length 120mm Copper Nut+
