Homemade Sheet Metal Brake
Introduction: Homemade Sheet Metal Brake
Materials
Angle iron 120cm x 50mm x 5mm Square tube 60x2 mm M20 & M16 threaded rod with nuts and washers 26mm round tube 18mm hinges
Teacher Notes
Step 1: Make It
Mark and cut the grooves for hinges. for 18mm cut 9mm for each one.
Weld the hinges on.
Then cut the 2 edges of angle iron and weld it upsdown. Mark and drill 22mm holes for m 20 thread rod.
Weld the adapters on m20 rod and put it in 22mm hole with washers up and down and weld big spots on the rod or use a spring.
For the handle weld a nut m26 on 26mm tube then weld the nut with rod on the angle iron.
Paint with primer and with color you like.
Be the First to Share
    • Trash to Treasure Contest
    • Rope & String Speed Challenge
    • Wearables Contest
      Wearables Contest
