Homemade Water Filter!!!
Materials:
  • Fine sand
  • Gross sand
  • Fine gravel
  • Gross gravel
  • Stones
  • Cotton
  • Gauzes
  • 6 Bottles
  • Scissors
  • 3 wooden boards of the same size
  • 12 large woods
  • Big screws
  • Hose
  • Silicone
  • Purple cabbage
  • Water
  • Glass or metal vessel
  • Drill
  • Aluminum Sulfate [Al2 (SO4)3]
  • Calcium hypochlorite [CaClO2]
Step 1: For the Filters
Each bottle must have multiple layers to filtrate the water
Step 2:
Cut the upper part of your 6 bottles, save that parts for later
Step 3:
Take some cotton and push it into the bottleneck, do the same for the 6 bottles
Step 4:
Place a thin gauze layer above the cotton (also for the six bottles)
Step 5:
Take some fine sand and put it above the gauze
Step 6:
Place another gauze layer above the sand
Step 7:
Repeat the same procedure with the gross sand, fine gravel, gross gravel, stones and coal, don’t forget to put a layer of gauze between them
Step 8: For the Structure
We’ll make a table-like structure to hold the filters
Step 9:
Take the 3 wooden boards of the same size, and draw some circles, tree on the first table, two on the second and one on the third one. The circles must be a little bit bigger than the bottleneck.
Step 10:
With a drill start making the holes on the wooden boards. BE CAREFUL, use glasses and gloves
Step 11:
On the corner of each board do one small hole with the drill, they will help to place the screws.
Step 12:
Take the 12 large woods (they will be used for the table legs) and do small holes on top of each one with the drill (the same holes that we did before)
Step 13:
With the drill and screws we’ll join the wooden boards with the large woods to do the tables. At the end we’ll have 3 “tables” that will be placed one above the other
Step 14:
Take each bottle cap and do a hole as big as the hose diameter
Step 15:
Pass the hose through the hole and stick it with silicone, do the same with each bottle cap
Step 16:
Put each bottle cap on the bottles again and place the bottles in the structure
Step 17:
Cut the hose according to the distance between the filters
Step 18:
Put a glass or metal vessel behind the last filter
Step 19: ​For Water Quality
The usage of chemicals to purify water
Step 20:
Measure the amount of aluminum sulfate and calcium hypochlorite, 1 teaspoonful of calcium hypochlorite and ¼ tablespoon of aluminum sulfate
Step 21:
Put each one above a piece of gauze and tie it up to do some small “bags” (similar to tea bags)
Step 22:
Then put the aluminum sulfate bag on the last bottle and the calcium hypochlorite bag on the glass or metal vessel
Step 23:
Remember we must change this bags every day
Step 24: ​To Measure Ph
We used a natural ph measurer to register our results
Step 25:
Cut the purple cabbage on small pieces
Step 26:
Boil the cabbage with water for 5 minutes until some parts of it turn green
Step 27:
Wait for the water to cool and put only the purple liquid in a bottle
Step 28:
Prove it with coca cola (for example), put some cabbage water on a glass and add the same amount of coca cola, if it turns to a red-like color it’s working
Step 29:
You can also prove it with the two chemicals we used before, it will turn greenish for the calcium hypochlorite and purple for the aluminum sulfate.
Step 30:
Now we’ve finished we just need to prove it, remember after our water is already filtrated we must boil it
    • Paper Contest
      Paper Contest
    • Trash to Treasure
      Trash to Treasure
    • Organization Contest
    seamster
    8 months ago
    Interesting idea, thank you for sharing this! :)
