Introduction: Engine Heads Buffing and Cooling Fins Painting Honda Magna VT250
About: Informative How-to videos. Catch Us on Youtube http://bit.ly/37Jenkh
This is how I restored the shine to my 1995 Honda Magna
VT250
motorcycle Engine.
SUBSCRIBE to our channel for more exciting videos in the Future ! : http://bit.ly/37Jenkh
---------------------------------------------------------------------------------------- Follow us: Facebook http://bit.ly/37Jenkh Instagram http://bit.ly/37Jenkh ----------------------------------------------------------------------------------------
Step 1: Wash the Cylinder Heads
The first thing that you need to do is wash the cylinder heads with kerosene and car wash liquid to remove all the caked on grime.
Step 2: Sanding Process
Next,start the sanding process using a 220 grit wet- sandpaper, and then step up with 400, 600and 1000.
Make sure to wear a mask when sanding.
Keep the cylinder heads pretty wet when doing it.
Step 3: Buffing
After sanding, the entire surface should be thoroughly cleaned and ready for buffing. it is important to ensure that they are free of grit or dirt as these will scratch the newly prepared surface. Then buff it off with a buffing wheel although the buffing makes a difference.
Make sure to wear a suitable eye protection because particles will be emitted at high speed from the wheel.
Step 4: Cooling Fins Painting
sand it with a 220 grit sandpaper then paint them with high temperature engine paint.
Step 5:
Take your time and do a good job.
Thanks a lot for watching, I hope you liked the video!
Suggestions and comments are welcome.
