Honey Clicker - Wireless Mouse in Honey
About: I make small games in a small apartment
I'd like to introduce you to the future of clicking: The Honey Clicker.
It is a functioning wireless mouse suspended in honey that is only capable of left clicking.
Supplies:
Jar of Honey, Wireless Mouse, Small Arcade Button, AA Battery, some wires + solders
Teacher Notes
Step 1: Get a Cheap Mouse
First step in this project was googling if it could work (milk will not work).
Then, I bought a cheap wireless mouse.
Step 2: Pry Open the Mouse and Solder Some Wires
Open up the mouse with a screwdriver or something and rip out all the relevant pieces.
Solder the battery leads to loose wires and connect an arcade button to the left click on the circuit board.
Step 3: Get to Dipping
To make sure the battery will actually work in the honey, give it a dip. With the dongle plugged into your computer you should be able to click using the arcade button. The red LED on the circuit board should also light up.
Make sure the mouse is switched on. This is something you'll want to do before the circuit board is covered in honey.
Use a tight rubber band to hold the wires on the battery.
Step 4: Make Sure the Whole Board Fits
Uh oh, looks like the board is a bit too wide for this honey jar.
Step 5: Figure Out What You Can Afford to Get Rid of on the Board
Determine which part of the circuit board you can get rid of to make it fit. Any connections on this part of the board will need to be traced to another part of the board. Use your multimeter to confirm and resolder those wires.
Step 6: Saw Off the Part That Doesn't Fit
Be careful!
Step 7: Dip the Whole Thing!
You may need to dump out some honey first, but you'd be surprised by how little honey the board displaces.
Step 8: Drill a Hole in the Top for the Button
You'll want it to be snug so honey doesn't spill out if it gets turned over.
I used plug connectors to connect the button to the board so that I could keep the button relatively honey free while I worked on the rest of it.
Step 9: Seal It Up and Get to Clicking
That's it! You have a Honey Clicker.
The wireless mouse should go to sleep when not in use so the battery should last you a while. In the meantime, you can press the button on the honey jar to left-click as needed.
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    3 Discussions
    Alex in NZ
    8 weeks ago
    I am very impressed by the how. Thank you :-) (The "why", doesn't really matter)
    randofo
    8 weeks ago
    The next version should have an acceleromter to move the mouse and a pressure sensor so that you can click by squeezing.
    audreyobscura
    8 weeks ago
    The honey doesn't disrupt the conductive soldering points of the PCB? Amazing.
