Hot Glue Secret Wood Pendant
846
32
6
Introduction: Hot Glue Secret Wood Pendant
About: I love upcycling trash into treasures, especially creating small things like jewelry and gems.
If you don't want to deal with resin but like secret wood pendants - I have a craft for you! You can combine hot glue with wood and it looks really cool :) You won't need any power tools and not even a glue gun. So let's start!
Supplies:
  • hot glue sticks (stiffer glue sticks are better than more flexible ones)
  • craft knife (make sure it's sharp!)
  • candle
  • hair dryer
  • wire or eyepins
  • Optional:
  • watercolors or acrylic paints
  • felt tip pens, sharpies, fineliners...
  • clear nail polish
  • white glue
Teacher Notes
Step 1: Prepare Your Branch
First, get some branches from outside. That way you can make art with wood from special places :)
Break a branch in order to get some nice texture. I believe that "fresh" branches have a really nice texture, but any older branches will work too.
Then carve the bark of the tip away (unless you like to leave it).
Step 2: Optional: Paint the Wood
At this point you can stain or paint the wood with acrylic paints, watercolors or other paints.
Step 3: Melt Some Glue
Take a hot glue stick, cut a piece off of it and hold one end above a candle flame. You want it to melt really well until it almost starts dripping.
Then quickly push the branch inside the glue stick. It normally won't go very far though. That's where the hair dryer comes in: Use it to get the glue further down the branch and remove air bubbles.
I am not sure if this helps, but I put the glue into the fridge so it cooled down faster. I believe it makes the glue more transparent, but I couldn't confirm that hypothesis ;)
Step 4: Carve Away
When the glue has completely cooled down, you can take a cutting board and carve the glue with a craft knife into a crystal-like shape. This might require some practice and you need to be careful not to cut yourself, but a cutting board really helps.
When you are done, you can cut through the branch wherever you want the pendant to end. This will be easiest with a saw, but it works with a craft knife as well. The wood can be sanded for a nicer finish, but unfortunately you can't sand the hot glue.
Step 5: Making Pendants
In order to make pendants, I used two options:
  1. Take a map tack and carefully make a hole. Then insert an eyepin with some superglue.
  2. Make a groove with your knife and use it to wire wrap your pendant.
Step 6: Varnish
What really gives your crystal its transparency is some varnish. I used clear nail polish, but white glue works as well.
Step 7: Optional: Add Some Color
You can also decide what color you want your crystal to have. Just use literally any kind of marker, fineliner, sharpie or whatever you have and paint the crystal.
Next, take any white glue and brush it on. It will dry clear and look great!
Just be aware that lighter colors are more transparent and darker colours can hide some of the nice details inside the crystal.
Hope you like this idea and have a nice day! :)
Hot Glue Speed Challenge
1 Person Made This Project!
  • Magnets Challenge
    Magnets Challenge
  • Warm and Fuzzy Challenge
  • Wearables Contest
    Wearables Contest
6 Discussions
jiovanie
jiovanie
Tip 2 months ago on Step 7
This is great! One thing I want to mention is that I've seen glue sticks in stores that are perfectly clear and not hazy so those would be perfect for this!
Randomona
Randomona
Reply 2 months ago
Thank you! :) Yeah that's true those work really well!
hughemor7366
hughemor7366
2 months ago
Really nice alternative to resins! Nice job
Randomona
Randomona
Reply 2 months ago
Thanks a lot I'm glad you like it! :)
jessyratfink
jessyratfink
2 months ago
Really creative and pretty :)
Randomona
Randomona
Reply 2 months ago
Thanks a lot! ^.^
