Ever need solder in a hurry? You need a hot glue gun!!!
For this Hot Hot Glue Gun project you will need a:
Hot Glue Gun (duh)
Wire Strippers
Wire
Multi Meter (Optional)
Teacher Notes
Step 1: STRIP THE WIRE
Use your wire strippers to strip 1.5 cm off the ends of the wires.
Step 2: JOIN THEM UP
Wrap the wires around each other so they are touching.
Step 3: GLUE IT
Glue around the wire to hold connection together.
Step 4: THE FINISHED PRODUCT
The finished product should look like this.
Use a Multi Meter on resistance setting. if it says 1 it failed if it says 0.00 you did it!!
Hot Glue Speed Challenge
4 Discussions
24 days ago
dont forget the flux
4 weeks ago
How reliable are these joints ? I would expect them to fail fairly soon through oxidation of the copper.
Reply 25 days ago
In my testing I have found that the joins are waterproof but to combat any oxidization, you can use head shrink tape or sleeves to reinforce the join. You can also glue the heck out of the wire.
Tip 4 weeks ago
keeping the glue close to the wires can help with waterproofing, if necessary.
