this project is how to make a hot glue replica of your teeth.
Supplies:
for this project you will need a hot glue gun, clean oil based clay, an old toothbrush, and white acrylic paint,
Teacher Notes
Step 1: Step 1: Making the Molds.
bite into the clay, making a mold of your top set of teeth, do the same for the lower set of teeth.
Step 2: Step 2:
slowly squirt the glue into the molds. run the molds under cold water for about 30 seconds. let them sit five minutes, then remove the clay.
Step 3: Step 3: Finishing Up
use the toothbrush to clean off the clay, if you don't get all the clay off that is fine because you are going to use white acrylic paint, when you finish painting the teeth let them dry. (optional: add another coat of paint.) let me know how this turns out for you.
2 Discussions
12 days ago
Neat! I'm having flashbacks to the "Invisible Man" move where the guy painted his teeth with TippeX (Liquid Paper, ?US name) to make them look right. Thank you for sharing your ideas :-)
15 days ago
Great idea! It would be fun to make some goofy Halloween teeth with your method.
Thanks for sharing!
