House Bot
Introduction: House Bot
Teacher Notes
Step 1: Cut the Cube Net.
Carefully, cut the cube net along its perimeter. Once cut, set aside.
Step 2: Repeat Step 1 Again With the Square Base Pyramid.
Again, Cut along the perimeter of the square pyramid.
Step 3: Start Coloring!
Take the cube from step one and start coloring each side. Each "Face" of the cube should be a different color.
Step 4: Result of Coloring Each Side.
Color the center four boxes as Yellow, Magenta, light orange, and light blue. Color the left-wing light pink and color the right-wing green. You can choose your own colors if you want.
Step 5: Repeat Coloring With the Square Based Pyramid.
Color it yellow.
Step 6: Start Folding Along the Lines of the Cube Base.
Step 7: Fold the Flaps Along the Lines.
Step 8: End Result of Step 7.
Step 9: Apply Glue on the Sides of the Triangle Without a Flap.
Step 10: Push the Two Sides Together and Attach Them With the Glue.
Step 11: End Result of Step 10.
Step 12: At the End, Your Figure Should Look Like This.
Step 13: Repeat Steps 6-11 Until You Get a Cube.
Step 14: Glue the Top Triangular Piece With the Cube.
Step 15: Draw a Face on the Top Triangle With a Black Pen.
Step 16: Draw Out Two Rectangles for the Hands and Two More for the Feet and Cut Them Out.
Step 17: Attach the Hands and the Feet Using Glue.
Step 18: Final Result!
Be the First to Share
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
    • Wearables Contest
      Wearables Contest
