Introduction: How to Make a Paracord Bracelet (2 Colors)
This will show you how to make a paracord bracelet with:
A Buckle
Two 4 foot long ropes of paracord
A lighter
Knife or scissors
Step 1: Step 1
Use your lighter to fuse the rope together.
Step 2: Step 2
After that get your buckle and the rope put the rope through the buckle.
Step 3: Step 3
Then pull the buckle to the end of the rope and loop it like in the picture.
Step 4: Step 4
For every inch that you want your paracord to be on your wrist then use a foot of rope to start so if you want the rope to be 7 in use 7 feet of ropes (4 feet of each rope)
Step 5: Step 5
Now you start the braid you go over with the rope you want to be in the middle. Then with the other color you put that over the other rope then you go under with that rope. It should look like a pretzel and then pull tight. The photos make it easer.
Step 6: Step 6
After that you keep repeating the steps until you get the rope to where you want it to be.
Step 7: Step 7
After you get it to the end you need to cut the rope close to the end and burn it down with the lighter. ( sorry for the change in lighting in the room)
Step 8: Now Your Done
It should look like this
Hope this was helpful.
