Introduction: 3D Beaded Ball!!
About: I post how to videos on youtube and run my own business on the side making hand crafted keychains, Jewelry and other items. One of my main goals in life is to help as many people as I can and just knowing tha…
This instructable will show you how to make a 3D beaded ball
Please subscribe to my channel
Step 1: Gather Materials
1. you will need :
a) 30 Beads of your choice
  • I used 4mm Metallic Black Bicone Beads
b) Fishing Line
  • I used 4 pound fishing line
c) A pair of Scissors
Step 2: Fold Line in Half
1. Cut a piece of fishing line
  • Make sure you have a fairly long piece of line
  • You want to be sure you have enough line to finish the project without running out of line
2. Fold fishing line in half
  • Make sure that both ends are even
3. Paint the left end of the line red
  • I used red nail polish
  • You can use any color nail polish you like
  • If you don't have any nail polish, you can also use a permanent marker
Step 3: Make a Circle of 5 Beads
1. Put 5 Beads on the left end of the line (Red)
2. Put the right end of the line (Clear) through the last bead you added in the opposite direction
3. Hold both ends of the line even
4. pull to the centre of the line
Step 4: Make Circle #2
1. Put 4 Beads on the left end ( Clear) of the line
2. Put the right end (Red) of the line through the last bead
3. Pull to the centre
4. Put the right end (Clear) into the next bead
Step 5: Make Circle #3
1. Put 3 Beads on the left (Red) end of the line
2. Put the right (Clear) end of the line through the last bead
3. Pull to the centre of the line
4. Put the right (Red) end of the line into the next bead
Step 6: Make Circle #4
1. Put 3 beads on the left (Clear) end of the line
2. Put the right (Red) end of the line through the last bead
4. Put the right (Clear) end of the line into the next bead
Step 7: Make Circle #5
1. Put 3 beads on the left (Red) end of the line
4. Put the right (Red) end of the line into the next 2 beads
Step 8: Make Circle #6
1. Put 2 beads on the left (Clear) end of the line
Step 9: Make Circle #7
Step 10: Make Circle #8
4. Put the right (Clear) end of the line into the next 2 beads
Step 11: Make Circle #9
1. Put 2 beads on the left (Red) end of the line
Step 12: Make Circle #10
4. Put the right (Clear) end of the line into the next 3 beads
Step 13: Make Circle #11 and Circle #12
1. Put 1 bead on the left (Red) end of the line
4. Put the right (Red) end of the line into the next 4 beads
5. Tie a knot with the left (Clear) end of the line
6. Tie one more knot to make sure it is secure
7. Cut off the extra line
