Eyeliner is simultaneously one of the most basic and challenging skills for a makeup wearer to learn. In my opinion pencil eyeliner is the easiest to learn so that's where we'll start. This tutorial is for beginners so I will not be adding a wing.
Supplies:
Pencil eyeliner: I used Burt's Bees Nourishing Eyeliner Pencil in black.
Lid primer or concealer (optional): I used Urban Decay's Primer Potion.
Eyeshadow (optional): I used Colourpop's Double Entendre palette.
Eyeshadow brush (optional): I used the Morphe E13.
Makeup sponge (optional)
Teacher Notes
Step 1: Start With Clean Skin
All cosmetics apply will apply more easily to clean skin, so wash your face!
Step 2: Prime Your Lids
If you do not have a lid primer or concealer skip to step 4, but I find that any eyeliner will last longer if applied over primer and eyeshadow. Dab the primer on your lids and blend into your lid with a makeup sponge or your finger.
Step 3: Apply Eyeshadow
This step is only necessary to set the primer from the last step. Choose a color close to your skin tone for a natural look. Take the color of your choice on a fluffy eyshadow brush such as the Morphe E13 and blend over your lids.
Step 4: Start With a Sharpened Liner
A sharp pencil will produce a clearer line and is more sanitary, which is a must for anything going near your eye!
Step 5: Drawing the Line
Use short strokes to connect the outer corner to the inner corner of your eye. Try opening your eye once you are halfway across your lid to achieve a more predictable result and keep the pencil as close to your lash line as possible.
Step 6: The Finishing Touches
Once your initial line is drawn you can go back in and smooth it out with your pencil to get the best result.
2 Discussions
26 days ago
Thanks for your liner tips! I'm always feeling a little unsteady bridging the middle to the edge.
Reply 25 days ago
Thank you!
