How to Assemble a Pedestal Electric Fan?
Electric fans are one of the most useful appliance ever made, it give's us ventilation and coolness in every room. It is a necessity in every household, offices and in any place, thus one should know how to assemble an electric fan. It's very easy as 1-2-3, even a kid can do it.
Supplies:
Parts:
  1. Base
  2. Pedestal
  3. Motor head
  4. Switch set
  5. Rear guard
  6. Front guard
  7. Guard ring lock
  8. Blade
  9. Screws
Tool:
  1. Screwdriver set
Teacher Notes
Step 1: Establishing the Base
Screw the pedestal to the base using philips screwdriver (4 screws)
Step 2: Connecting Motor Head to the Pedestal
Place the motor head on top of the pedestal and insert it to the tubular metal stand.
Step 3: Tightening the Screw Knob
Tighten the screw knob on the motor head to the tubular stand.
Step 4: Connecting the Switch
Slide the switch at the back of the motor head to connect in the unit.
Step 5: Screwing the Rear Guard
Screw the rear guard to the motor head using a phillips screwdriver (4-screws).
Step 6: Screwing the Blade
Insert the blade to the motor shaft and screw it.
Step 7: Placing the Ring Lock
Place the guard ring lock on the front guard, let it hug the rim of the front guard.
Step 8: Fitting the Front Guard
Fit in the front guard to the rear guard, then tighten the screw of the ring lock.
Step 9: Adjusting the Height
Adjust the height of the fan by loosening the knob on the pedestal to the desired height.
Step 10: Plug-in
Connect the male plug-in to AC wall outlet.
Step 11: Switch On
Turn the switch knob to test its functionality
Step 12: And Your Done!!!
Be the First to Share
    • CNC Contest
      CNC Contest
    • Teacher Contest
      Teacher Contest
    • Maps Challenge
      Maps Challenge
