Introduction: How to Build a Planter Box for Herbs
About: I’ve done my fair share of DIY projects, including home maintenance, decoration, school projects, vehicle repair and even some cooking the dad way. As a home handyman I find it really rewarding to complete a j…
Overview
I needed a planter box that wasn't very big so I could grow some rosemary and thyme. These tend to grow quite bushy, so the planter box could be too small either. The design I decided on suits it just fine, and I made it from recycled and left over wood I had already, so it didn't cost me anything.
Disclaimer
This instructional guide and the material covered is for informational purposes only. I take no responsibility for what you do with this knowledge.
Safety Information
Use safety equipment when operating equipment. Take necessary precautions to avoid injuries to persons/animals and damage to property when operating equipment. Always abide by the manufacturers safety information and warnings when using equipment.
Dad-DIY.com is a participant in the Amazon Services LLC Associates
Program, an affiliate advertising program designed to provide a means for sites to earn advertising fees by advertising and linking to www.amazon.com
Tools required (linked to my recommendation)
Materials required (see figure 1):
(1) Timber 2x6, Length: 7 inch (178 mm), Qty: 1
(2) Timber 2x6, 4 ft long 4 ft (1.2 meters), Qty: 1
(3) Plywood 1/2 inch thick, Length: 50.2 inches (1276 mm), Width: 3 inches (75 mm), Qty 2
(4) Plywood 1/2 inch thick, Length: 50.2 inches (1276 mm), Width: 2 inches (50 mm), Qty 4
(5) Screws, 2 inches (50mm), Qty 20
(6) Nails, 1/2 inches (25mm), Qty 20
(7) Black plastic, Length: 5 ft (1525 mm), Width: 1 ft (300 mm), Qty 1
Step 1: Instructions
  1. Cut a 2 x 6 piece of timber to the lengths and quantities specified for items (1) and (2) in the table above.
  2. Cut 1/2 inch plywood to the sizes specified and quantities for items (3) and (4) in the table above.
  3. Drill holes in the two items (2) and attach it to the item (1) using the 4 screws (5) , as shown in figure 2.
  4. Drill holes in the sides of the two plywood pieces (3) and attach it to the planer box using 8 screw (5), as shown in figure 3.
  5. Drill holes in the sides of the four plywood pieces (4) and attach it to the planer box using 8 screw (5), as shown in figure 4.
  6. Place the black plastic (7) inside the planter box. Fold the corners to make it fit, as shown in figure 5.
  7. Nail the black plastic (7) to the sides of the planter box using nails (6), as shown in figure 6.
  8. Cut holes in the black plastic for drainage.
  9. Fill the planter box with a layer of stones (for drainage), leaves, grass clippings at the bottom - this will breakdown to form compost over time. Add a soil mixture on top of this, suitable for the herbs or plant you will be planting. I used a half potting soil, half compost mixture for the rosemary and thyme, as shown in figure 7.
  10. Plant the herbs with enough space in between for growth. Give it a good soaking to settle the plants in, as shown in figure 8.
Visit www.dad-diy.com for more projects like this DIY planter box.
