How to Build a Powerful Metal Rc Robot Tank
686
10
4
About: Amazing Videos of Guides DIY, Explanations, Tips, Tricks and Much More
Good friends! So, I thought about a kind of project that would be interesting and I decided to build a tank (space crawl) on a sign of course that is built entirely of metal. 100% My construction is of high quality and accuracy, most parts of the tank have created myself from all sorts of leftovers left in various projects I have done in the past and call it the absence of toys in childhood or whatever. After a long week of planning and construction, the project finally came to an end and with it (how not?) The video documents the process of creation and assembly.
Step 1: Train the Tank Body
To put together the body I used light metal parts and aluminum I made some bending and created a massive and powerful tank body.
Dimensions: Length: 45 cm, width: 29 cm, height: 17 cm
Larval dimensions: length: 127 cm, width: 5 cm.
Control: by a sign and by a designated application for the phone.
Motor specifications: A pair of JGB37-550 24V engines with built-in chalk.
Step 2: Train the Tracks of the Larval Track
fter building the chassis of the tank approach the queen of the vehicle supporting wheels
Step 3: Train the Engines
Next step I assemble the engines that drive the tank, it is important to use strong motors with large torque
Step 4: Step Train the Slide Track
The stage I loved most was just fun
Step 5: Assembling Electronic Components and Recent Tests
Assembling electronic components and recent tests
Step 6: Last Stage
Of course, after I saw that all the mechanisms were working properly and the tank was going as planned, I decided to carry out another upgrade that was very important to me - to give the tank the power it needed - I upgraded the engines to much faster. Instead of 6V I increased to 24V, instead of 200 revolutions I increased to 1400 revolutions to the wheel that drives the larva.
Using planetary chalk (similar to an impact bolt). Changing the motors would also require a change in the battery, so instead of a 7.2V battery I upgraded to a 24V 9A rechargeable battery. The whole business allows me an hour and a half. I also installed a more advanced control and control system on the tank. For each engine I installed a separate brushless water-speed speed controller that allows me to control the speed of the drive through the remote control. And I also added control over the tank through an application. Of course, we will expand on all the changes in the next video, which will also include a test drive in challenging terrain conditions such as sand, grass, gravel, hike, etc.
In the next video that will be released very soon I will show you how the tank travels in difficult terrain Stay tuned for this coming soon
    • Backyard Contest
      Backyard Contest
    • Sew Tough Challenge
      Sew Tough Challenge
    • Sensors Contest
      Sensors Contest
    4 Discussions
    silver2row
    2 days ago
    Hello...nice video on producing something w/ metal, electronics, and bearings.
    I know everyone uses things differently, i.e. tools esp. I like to handle my screw driver by the tip in case I have to BOP someone on the head. I hate accidentally poking eyes out. Be careful and Godspeed!
    Seth
    dhaykus0418
    Tip 15 days ago
    Just an FYI on shop procedures, you should never, never, never, (did I mention never) place your angle grinder with the blade down like that. If something were to happen and it did not shut off or it suddenly was to come on, it could catch on your surface or other items and cause great injury spinning out of control (trust me I've seen it) in more than one shop setting.
    MissionCriticaldhaykus0418
    Reply 15 days ago
    i agree totally with you, infact i had one injury from angle grinder, luckily not that worse or so, but it definitely was bad idea to keep the angle grinder on floor like that!
    diyfixmandhaykus0418
    Reply 15 days ago
    Wait for the next video and you'll see how many upgrades I'm going to make
