How to Change a Tire
About: Information Science Student at UALR
Tools needed:
  • Jack
  • Jack Stand
  • Wrench
  • Spare Tire
  • Vehicle Owner's Manual
Step 1: Turn on Your Car's Hazard Light and Apply the Hand Break
Make sure that you put your car on P(park) and apply the hand break before stepping out of the car.
Step 2: Locate the Spare Tire
The spare tire is located in the trunk. Remove the trunk lining to get access to the spare tire.
Step 3: Begin to Loosen the Lug Nuts Using the Lug Wrench
Step 4: Raise the Vehicle
  • Refer to the Owner's Manual for proper placement of jack.
  • Using the jack, raise the vehicle until the tire is above the ground.
  • Use the jack stand for more weight support.
Step 5: Unscrew the Lug Nuts
Step 6: Remove the Tire
Step 7: Mount the Spare Tire
Mount the spare tire and tighten lug nuts by hand.
Step 8: Lower the Vehicle
  • Begin by removing the jack stand
  • lower the vehicle to the ground
Step 9: Tighten Lug Nuts Using the Lug Wrench
Step 10: Make Sure to Clean Up and Put Every Tool in Their Proper Place.
Putting the tool in their proper spot makes it easier to access for future use.
    • Organization Contest
    • Trash to Treasure
      Trash to Treasure
    • Epilog X Contest
      Epilog X Contest
    4 Discussions
    rdarling0003
    5 months ago
    My niece who is now driving just finished watching your indestructible at least now I pray she won't have to call me in the middle of the night
    Lorddrake
    5 months ago
    good job recommending the jack stand. I keep one in my vehicle because I never trust a scissor jack to stay in place (the voice of experiences past)
    Lorddrake
    5 months ago
    one important fact that you should add is that it is best to tighten the lug nuts in an alternating pattern. for a 5 lug setup as shown in this IBLE you should tighten the lugs in a star pattern. top - bottom right - side left - side right - bottom left - back to top (repeat until fully tightened)
    This will tighten the lugs down evenly and ensure an even distribution of pressure across the wheel mounting surface
