How to Control Bulb by Using Arduino UNO and Single Channel 5V Solid State Relay Module
Introduction: How to Control Bulb by Using Arduino UNO and Single Channel 5V Solid State Relay Module
Description:
Compares with the traditional mechanical relay, the Solid State Relay (SSR) has many advantages: it has a longer life, with a much higher turn on/off speed and no noise. Besides, it also has better resistance to vibration and mechanical shock, and better moisture proof performance.
Specification:
  • Control Voltage:5V
  • Static Current:0mA
  • Working Current:13.8mA
  • Size: 25mm x 34mm x 25mm (Length*Width*Height)
  • Input voltage: 5V DC
  • Maximum Output Current: 2A
  • Maximum Output Voltage: 240V AC
  • Input Voltage of Control Signal: 0-2.5V (low level state), the relay will be on; 3-5V (high level state), the relay will be off.
  • Triggered at low level
Teacher Notes
Step 1: Material Preparation
The photo above shows item needed in this tutorial:
  1. Bulb.
  2. Arduino UNO.
  3. Bongkah.
  4. Single Channel 5V Solid State Relay Module.
  5. Jumper Wire
Step 2: Follow the Video
Step 3: Source Code
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
