How to Create a HYDROPHOBIC Self Cleaning Toilet!!!
Introduction: How to Create a HYDROPHOBIC Self Cleaning Toilet!!!
I hate cleaning the toilet! I had an idea what if I sprayed that never wet stuff from rust oleum onto the toilet. If nothing sticks to this hydrophobic surface would it be easier to clean the toilet. I couldn’t wait to try this. I found never wet at Ollies for a dollar, so there’s really nothing to lose except a dollar. So I drained all the water out of the toilet make sure that it was totally dry by using a hair dryer, then put part one and then park to just like the directions say. Wow! Wow! You have to see the video to see how a toilet looks before and after hydrophobic compounds are put on the surface.
Step 1: Prep for Spray
To get all the water out of the toilet bow, turn off the water valve and flush the toilet to get as much water out. To get the rest of the water you can use the lid to the cans to scoop it out. Then dry the surface of the toilet with a hair drier to get all the water out.
Step 2: Spray
Put on the spray in even coats allowing 30 minutes between the base coat and the top coat
Step 3: Finished
Now go ahead and turn the water back on and let the bowl fill up. When you flush the toilet it looks so crazy!! I can explain what it looks like. Make sure to watch the video to get a better effect.
Be the First to Share
    • Exercise Speed Challenge
    • Pocket-Sized Speed Challenge
    • Audio Challenge 2020
    3 Discussions
    waynoedm
    waynoedm
    1 year ago
    So what is the verdict?
    waynoedm
    waynoedm
    1 year ago on Step 3
    OK. I checked this out for giggles. Definitely curious how the coating is affected by solids. ;) Or if anything stains it. You'll have to fill us in on this after a bit of use. :D
    ironsmiter
    ironsmiter
    Reply 1 year ago
    I am curious too. The "rough texture" seems like it would do more harm for grabbing onto solid waste than good from the hydrophobic nature.
    I think this treatment would be absolutely magnificent on a urinal though.
