How to Create or Fix a Lock Button for a Grinder Makita
Introduction: How to Create or Fix a Lock Button for a Grinder Makita
About: Amazing Videos of Guides DIY, Explanations, Tips, Tricks and Much More
Some lock buttons I have broken in my life, you could say I'm really talented at breaking the grinder lock buttons but in the next video I found a way to show you how to easily create a new lock button in a few minutes!
Teacher Notes
Step 1:
To start first you have to disassemble the Grinder head, loosen the four screws marked in the picture. Keep all screws in a small box so they don't get lost. After unscrewing the four screws, use a flat screwdriver to remove the Grinder chalk cap
Step 2:
After disassembling we will start to create the new button, take a 6X30mm screw and drill a 3mm hole in it, then take a suitable spring and thread it into the screw.
Step 3:
Now we have to put the button that we created, put the button in the right place, and on the other side we put a penis that will keep the button in place. Then we push the button and check that it works properly and all parts can be replaced.
Step 4:
This is how we created a new button with no effort at all! Now you can get started. To better understand the steps, I encourage you to watch the full video on my YouTube channel.
Step 5: Watch the Full Promotional Video
Fix It Contest
This is an entry in the
Fix It Contest
Be the First to Share
    • Trash to Treasure Contest
    • Rope & String Speed Challenge
    • Wearables Contest
      Wearables Contest
