How to Create the Yakeba Insect Hotel
120
Introduction: How to Create the Yakeba Insect Hotel
In this Instructable, I will show you how to create an outdoor insect hotel using the Yakeba construction set. Check out these 10 simple steps to make one of your own, and watch the video for more detailed instructions. Scroll down for video.
Step 1: Materials
  1. wood
  2. screws
  3. wood glue
  4. wooden blocks
  5. nails
  6. hammer
  7. sheet metal
Step 2: Housing
First, screw one side to the floor piece.
Step 3: Housing
Put some glue into the rear panel groove, insert the rear panel and screw on the second side.
Step 4: Housing
Screw the two halves of the roof with the groove and fix them on the housing with the short screws. Countersink the screws well.
Step 5: Filling
Place the housing with the opening facing upwards. Place wooden blocks without glue for testing.
Step 6: Filling
Empty the housing. Apply the glue on the inside of the back wall and on the back of the wooden blocks. Do not apply glue to the sides! Insert the wooden blocks with the hole facing upwards and press down. Press parts together as long as the glue is moist.
Step 7: Filling
Put the reeds one by one into the gaps until everything is firm. Optional: Remove the burr on the front of the reed with sandpaper.
Step 8: Roof
Screw together the two large roof halves without groove with glue addition and then with the body. Fix the sheet metal with the nails. Done!
Step 9: VIDEO
Be the First to Share
    • Lighting Challenge
      Lighting Challenge
    • Puzzles Speed Challenge
    2 Discussions
    audreyobscura
    audreyobscura
    1 year ago
    Awesome birdhouse! Thanks for sharing your design and build!
