How to Cut Glass - With (nichrome) Wire
About: always had a deep connection with junk. drawn to it, magically, from childhood on. spent the nights as a boy roaming the streets and looking for trash to take back home. spent # 2 most of my allowance on the...
to show the technique: lets just chop off a bottle. a piece of nichrome-wire and some current will do. its easy. fast. cheap (all materials used here are pulled from the trash. as always: go dumpster-diving)
__note: *nichrome*,
& what the hell is that? well, thats the heaven you can gut out of an old hair-blower or toaster etc.
Teacher Notes
Step 1: The Victim
to be guillotined: a glass-bottle from the trash.
__btw 1, this works not just on round objects
__btw 2, the following cut is done without any scoring of the glass (see a future-post on that)
Step 2: How to Rig the Wire
as my master back in germany used to teach us:" keep it simple, stupid!"
the trick, if any, is to get a tight fit around the object you want to cut: without shorting the circuit later.
so here i opt for a little piece of (ply)wood from a fruit-crate; quickly customized as follows:
_1 make a (square or rectancular) small hole - (i just use a screw-driver and punch it through the wood).. through this hole the two ends of the wire-loop will come out , very close to each other b u t not touching
_2 to create some kind of lock of the wire-ends i just make two cuts on each side of the center-hole (see picture - i used any small saw that was flying about up here in the cabin)... the ends of the loop coming out of the hole will just be snaked through the slits (this, friction, helps tighten the loop around the body to be cut, as well as prevents loosening - just think of it as a simple ´belt´)
Step 3: Going Live With Juice
the electrical part is even easier:
i use a transformer (220v > 12v, 4amps) from a trashed bathroom-vanity. and i was about to control it with an old dimmer (but that critter didnt feel like showing up for work today). so i cheat a bit and replace it ih some gadget i banged together the other day (some ac-regulator coupled with a voltmeter - see pix).
anyhow: the idea is to connect the transformer on the down-side to the nichrome-wire loop (see pix - using some simple croco-clips.. wires not shown). the upside i run through the controller (or any old dimmer etc will do), simply to have some margin on the resulting heat of the wire.
hook it all up and connect it to some powersource (here 220v outlet from solar-kit).
moment of truth 1: i applied about 180v for about 20 seconds
then, right away, get ready for some:
Step 4: Shock
your wiring quickly unplugged or switched off from the main-source:
comes the moment of truth #2: just dip the bottle with (again, d e a d ! ) wires in some receptacle containing cold water you have prepared sitting on the side.
the bottle will snap (thermo-stress) along the wire-trace (not even having been scored)
..... done
thank you all.
any positive and negative feedback welcome, questions even more so.
work less and play more, over&out.
un abrazu de los picos de europa.
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    2 Discussions
    Uncle Kudzu
    26 days ago on Step 4
    Thanks for sharing this!
    I have all necessary junk for this. Would scoring the bottle first make for a more even cut?
    la xerraUncle Kudzu
    Reply 26 days ago
    _first, thanks for swinging by here
    _second, yes, definitely... best to score with a diamond-tipped glass-cutter... (or use any other hard and sharp-pointed object, like f.e. the tip of a masonary drill-bit.. just play around)
    ps, will post an entry at some point how you can score round objects, like bottles, easily and cheap (without buying any of that cray a$$ gadgets like in the picture
    ps, good luck,.. post your results if you are in the mood, hasta luego
