How to DIY RC Cars
When I was a child, I really wanted a remote control car. When I saw someone playing a remote control car, I was envious of death, but I didn’t have the money to buy it. Because I like DIY since I was a child, but the technology is very bad, I only play with a small light bulb or something. When I grow up, I have a certain amount of hands-on ability, I want to be a car myself. After several failures, I finally succeeded. I am grateful to Dexter for helping me. I was inspired by the post of his "loyal dog".
Teacher Notes
Step 1: First Prepare a Few Cardboard
Cut them properly and stick the 4 sheets together to form a thick board for the chassis.
Step 2: ​Step 2: Prepare the Wheels;
My wheels are removed from the four-wheel drive. It's a little small, but I can fix them and use them to penetrate them.
Step 3: Step 3: Prepare a Big Gear
it will be used for steering. Processing it like this, it seems that the change is not big, in fact, one of the holes is processed into strip holes
Step 4: Step 4: Fix a Part of the Two Used Refills on Both Sides of the Chassis With Hot Melt Adhesive
Fix the wheel to make such a structure
Step 5: Step 5: Use Dedicated Motor
Fix the motor, insert the big gear, and the steering system is completed.
Step 6: Step 6: Use Engine
Fix a part of the used refill with 502 super glue, plus the wheel
Step 7: Step 7: Fixed on the Chassis to Lead the Wire
Step 8: Step 8: Soldering the Receiving Board and Battery
Step 9: Step 9: Add a Rubber Band to the Steering Shaft of the Steering to Bounce Back to the Positive Direction
Step 10: Step 10: Make a Headlight
I just found two useless LEDs at home, so I used them to make the lights, soldered the switches and led them first. (I can't find the wires, so I have to use the enameled wire.
Step 11: Step 11:After Loading
Step 12: Step 12: Produce Remote Control
Step 13: Step 13: Put It Into Pieces
Take the line of each button and solder the board
Step 14: Step 14: Take the Power Cord Out and Bundle the Battery Underneath
Remote control production is complete!
Step 15: Step 15: the RC Car Is Completed
The overall photo frame (the shell is not going to be done, because it is not bad.)
This is the simple one and when I buy all parts of RC car, like, RC car lipo battery, I will remake another one.
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
