Introduction: How to Do the Perfect Manicure at Home
Hello friends! Today i'm gonna be showing you how to do the perfect manicure at home, first i wanna say that it's really important to take care of your hands and nails and keep them in perfect health especially in summer, an unhealthy lifestyle can have a negative effect on our hands and nails so doing manicures regularly will keep them hydrated and protect them from certain infections and skin problems, it's also a fun activity that you can enjoy yourself or do with your friends and siblings, learning how to do it will save you time and money so no more waiting in crowded expensive salons, now gather your supplies and let's get started!
Step 1: Tools and Products
- Cotton Balls : https://amzn.to/31GcSR6
- Nail Polish Remover : https://amzn.to/2Ks90xF
- Nail Clipper : https://amzn.to/2KTacJQ
- Nail File : https://amzn.to/2ILxm1S
- Soaking Bowl : https://amzn.to/2FiXmRj
- Antiseptic : https://amzn.to/2ZtSDnJ
- Towel : https://amzn.to/31KFWab
- Cuticles Hydrating Cream : https://amzn.to/2KqzkIC
- Cuticle Pusher : https://amzn.to/2XoLY0D
- Cuticle Softener : https://amzn.to/2InV6u2
- Nail Wood Stick : https://amzn.to/2Fj0rAR
- Cuticle Nipper : https://amzn.to/2Io5YIu
- Nail Cleaning Brush : https://amzn.to/2IYndzk
- Cotton Swab : https://amzn.to/2RvSU6Z
- Rubbing Alcohol : https://amzn.to/2IWDMeD
- Nail Buffer : https://amzn.to/2Rn2xEK
- Callus Remover : https://amzn.to/2Kp0M9y
- Hand Exfoliating Scrub : https://amzn.to/2KoRSsA
- Top Coat : https://amzn.to/2XnXhGk
Step 2: Examining Nails
The first thing to do is to start examining your hands and nails to determine the right steps for your nails and see if you have any cuts or sensitive areas that you need to be gentle around. Lol, my nails are a mess it's been a long time since i did a manicure and as you can see my nails are broken, uneven and my cuticles are super dry, but it's ok because today they're going to be fixed.
Step 3: Nail Polish Remover
After examining your nails, take a cotton ball and soak it in nail polish remover.
Step 4: Cleaning Nail Beds
Start rubbing the cotton ball on your nails one by one even if you don't have nail polish on, it's always better to start with clean nails and the nail polish remover will remove any dirt or remaining nail polish from the nail bed.
Step 5: Nail Clipping
After cleaning your nails, take a nail clipper and start trimming your long nails to make them all even in length, i'm gonna give my nails an oval shape so what i do is i make 2 small cuts on the sides of each nail and leave the center, if you have really short nails you can skip the cutting step.
Step 6: Nail Filing
So like i said earlier, i’m gonna do the oval shape, if you have short fingers the almond and oval shapes are the best to make your fingers look longer and if you have long fingers the square shape is the better choice to make your fingers look shorter. Now take a nail file and start shaping your nails, when using the nail file don’t go back and forth on your nail because that will cause splitting and breaking, the right way is to file in one direction and start from one side to the top to the other side in a smooth motion without pressing too hard on the nail.
Step 7: Soaking
Bring a soaking bowl, fill it with warm water and add drops of an antiseptic or an antiseptic soap, mix it well with the water then put your fingers in it and let your nails soak for 10 minutes, you can put a small ball in the bowl to keep your hand busy or you can watch some TV so you won't get bored .
Step 8: Drying
After 10 minutes, grab a clean towel, take your hand out of the soaking bowl and pat it with the towel until it's completely dry, after that, spill that water in the sink you won't need it anymore.
Step 9: Applying Cuticle Cream
Bring a cuticle pusher and a hydrating cuticle cream i recommend using Hard As Hoof nail strengthening cream, it's important to keep your cuticles moisturized to avoid cracking and dryness that can be painful and may allow bacteria in and cause infections, so dip the tip of the cuticle pusher into the cream and apply a small amount on all your cuticles. .
Step 10: Massaging Cuticle Cream
Massage the cream into the cuticle of each nail by doing a circular motion using your thumb on top and holding with the other fingers.
Step 11: Pushing Cuticles
Take the cuticle pusher and start gently pushing back the cuticle of each nail.
Step 12: Softening Cuticles
Take the cuticle softener and apply it on the cuticles to make them soft and easy to trim.
Step 13: Nail Wood Stick
Take a nail wood stick and use the spade shape tip to push out the small hanging pieces of the cuticles with going around it in a circular motion.
Step 14: Cutting Excess Cuticles
Take a cuticle nipper and start carefully and slowly cutting the excess cuticles, when you cut the cuticle don't pull it just place the nipper where you want to cut then press firmly on it and it will be easily cut, be careful not to cut too much. focus on how much you want to cut and do it slowly.
Step 15: Brushing Nails
After you finish cutting the excess cuticles, brush your nails with the small nail brush to clean them from any remaining cuticle pieces.
Step 16: Cleaning Nails
Take a cotton swab, soak it in rubbing alcohol and use it to clean under your nails
Step 17: Nail Buffing
Take a nail buffer and start buffing your nails (going back and fourth on the nail bed) until they become shiny.
Step 18: Removing Callus
If you work in constructions, lift weights or often use your hands to do heavy work, you will notice a layer of thick rough skin on the palm of your hands that is called callus and it can be removed easily, take a callus removing rasp soak it in a bowl containing warm water and antiseptic for 3 minutes then start rubbing the rasp on the callus for about 5 minute until it's all gone and the skin feels softer.
Step 19: Exfoliating Hands
Now it's time to exfoliate your hands, get a moisturizing hand scrub like Shea Moisture exfoliating hand scrub and apply it on both the palm and the back of your hand then wet your other hand and start scrubbing in a circular motion for 3 minutes.
Step 20: Rinsing
Rinse your hand with cold water and dry it with a towel, you'll notice that your hand feels softer and your nails become cleaner.
Step 21: Top Coat
If you're like me and want that extra shine, grab a clear top coat and apply it on your nails one by one and let it air dry.
Step 22: Results
And that's it! I hope you liked and enjoyed this tutorial, Bye Bye ❤️
My other Instructables:
https://www.instructables.com/member/Sarrella%20Blog/instructables/
My other blog:
Valentine’s Day Gifts!
Are you on a Budget, check out these fancy Valentine’s Day gifts under $50
https://medium.com/@ypipijou/best-valentines-day-gifts-under-50-3ffec7fa0c48
Step 23: Results Video
(Sarrella Blog is a participant in the Amazon Services LLC Associates
Program, an affiliate advertising program designed to provide a means for sites to earn advertising fees by advertising and linking to Amazon.com.)
Runner Up in the
Beauty Tips Contest
