How to Draw a 3D Car
Introduction: How to Draw a 3D Car
In this instructable you will learn how to draw a 3d car.
Supplies:
In this instructable you will need a Pencil, pencil sharpener, and an eraser.
Teacher Notes
Step 1: Draw a Diamond
First of all you will have to draw a Diamond. This is going to be for the front of the car.
Step 2: Draw the 3D Front of the Car
Now you will draw the front of the car, by drawing a rectangle at the left side. Then make the hole for the wheel by drawing a small line and then a semi circle. Remember to draw just a half circle, with no straight line going through.
Step 3: Drawing the Front Window
First draw a line connecting the semi circle and the diamond. Then you will draw a trapezium with just slightly tilted sides.
Step 4: Drawing the Roof
In this step you will have to draw the exact same diamond as on the first step, just it is attached to the front window. On the picture one line is missing, make sure to draw the entire diamond.
Step 5: Drawing the Left Side Window
For this step draw a diagonal line down to the level of the bottom of the front window. Then draw a straight line connecting the diagonal line and the front of the car.
Step 6: Drawing the Rest of the Side and the Wheels
Now draw another straight line below the one in the previous step, that has got a semi circle at the back. Then draw a straight line up indicating the 2 side windows. Afterwards draw 2 circles for the wheels.
Step 7: The Details
This step is all yours. you can copy mine, but this is where you can get creative. Make the front of the car etc.
Step 8: Example of All Details Together
Take a look at how I did it.
Step 9: Finish It
Now you can also still add a back of the car if you would like to. That works just the same as the front, but from another angle. Drawing 2 lines of both sides of the car forms the road. You can make a fence if you would like to.
Step 10: The Road
Drawing 2 lines of both sides of the car forms the road. You can make a fence if you would like to. This was the final step!
Be the First to Share
    • Heart Contest
      Heart Contest
    • Fiber Arts Contest
      Fiber Arts Contest
    • Paper Contest
      Paper Contest
