How to Draw an Eye: Introduction
91
I started to draw since before I could read. Drawing has always been part of my life. Over many years of practice, I have advanced my skills past the point of just a few years ago. Like you, I was a beginner or I want to get better, hoping to be a better artist motivated me and will motivate you. This drawing exercise is normal difficulty for beginners
Teacher Notes
Step 1: Materials!
First you will need these materials:
0.7 lead pencil
0.9 lead pencil
White paper (or drawing paper)
Eraser
A flat surface to have everything set on
Your finger
Step 2:
Starting with the 0.9 lead pencil draw a low dome shape like a small hill.
Step 3:
Make an under-dome and on the right side of both domes, connect in the middle.
The inner left, close the ends with an egg shaped point
Step 4:
Make a circle (about quarter size) on the inside of the eye and have no lines on the outside of the eye shape.
Step 5:
Now draw a drawn out swerve on the left inside of the eye about a milimeter in, and a line curved away from the iris (circle).
Step 6:
Draw an equally spaced 3x3 grid inside of the quarter sized iris (circe).
In the center of the 3x3 grid, draw a circle.
Color the smaller circle in completely and erase the 3x3 grid lines.
Step 7:
Now, make a cartoon sun flare around the inner circle.
Step 8:
Shade in the sun flare almost as dark as the pupil (inner circle).
Step 9:
Make a larger sun flare around the smaller flare.
Step 10:
Shade in the larger sun flare lightly.
Step 11:
Now, very lightly shade the rest of the iris (circle), do not shade outside the circle.
Step 12:
Use your finger to blend the center of the eye.
Step 13:
Darken the pupil (smaller circle) and shade it in darker.
Erase any additional and unwanted smudges on the outer lines, including the rest of the eyeball and on the outside of the eye.
Step 14:
Lightly shade the left-most area and the right-most area of the eyes drawn in step 5.
Step 15:
Use your finger to blend the outer ends and erase any additional and unwanted smudges on the outside of the eye.
Step 16:
On the upper dome on the outside make small upward curves starting from the most-right corner and make each smaller as you move to the left corner of the eye.
Stop about a centimeter from the end of the left-most side and the smallest lashes should be on the left side.
Step 17:
Now take the 0.7 lead pencil and on the upper dome on the outside make small upward curves starting from the most-right corner and make each smaller as you move to the left corner of the eye.
Fill in the empty areas, but not too much to the point where you can't see some of the white paper.
Step 18:
With the 0.9 lead pencil, draw on the lower dome on the outside make small downward curves starting from the most-right corner and make each smaller as you move to the left corner of the eye.
The bottom eye-lashes are about half the size of your top lashes, so make the bottom ones smaller than what you did on the top.
Stop about a centimeter away from the left-most corner of the eye and the smallest lashes should be on the left side.
Step 19:
Get the 0.7 lead pencil and on the lower dome on the outside make small downward curves starting from the most-right corner and make each smaller as you move to the left corner of the eye. Fill in the empty areas, but not too much to the point where you can't see some of the white paper.
Step 20:
Take the 0.9 lead pencil and draw a line about a centimeter above the top eye lid at a 45 degree angle (having the left side being the lowest point and the right end being higher than the left side).
Draw another line that is slightly curved, making a 45 degree in the opposite way.
Both lines meet at the same distance of the right-most eye.
Step 21:
Draw a similar angle connecting to the angle that you just made, but at a downward slope ending about a centimeter past the right-most corner of the eye.
On the larger angle, close the ends with a slight curve facing away from the eye.
Step 22:
Erase any extra lines inside and outside of the eyebrow.
Step 23:
Draw short lines inside of the eyebrow, and continue throughout the entire eyebrow.
Step 24:
This is what it should look like when you are done with the whole eyebrow.
Step 25:
Take the 0.7 lead pencil and fill in some areas, but make sure NOT to fill in the entire eyebrow so that you can't see some of the white paper.
Step 26:
Use your finger to blend the area of the eyebrow and erase any additional shading outside of the eyebrow.
Step 27:
Draw small extended hairs (lines) on the outside left-most side of the eyebrow.
Step 28: You're Done!!
Recognize that this exercise does not go into great detail about the realistic features of the eye. If you would like, go to Google Images to further your skills lie I used it to further my skills. I hope this tutorial helped you in learning how to draw an eye better or get the basic steps of it. Thank you!
1 Person Made This Project!
  • Book Character Costume Challenge
  • Made with Math Contest
  • Cardboard Speed Challenge
