How to Fill a Keurig Automatically
91
Keurig's are great, but their water tanks have to be filled constantly. For under $20, you can install a float valve and connect a line to your sink's cold water feed line. No Plumber Required! Never fill your Keurig again! Watch the video above or read the steps below.
Step 1: Ready the Float Valve
Buy an aquarium float valve. Screw a 4 inch piece of copper wire under the mounting nut and bend it so you have two little feet on the side.
Step 2: Glue Valve Into Tank
Super Glue the feet and stick them inside the tank, just above the fill line, on the flat side of the tank, so that the water inlet points to the back.
Step 3: Connect Water Line
Drill a 1/4 inch hole in the back top of the tank and push 1/4" poly tubing through and into your valve.
Step 4: Tap Into Water Source
Under Kitchen Sink, turn off cold water line and unscrew sink hose. Screw in Tee and connect other end of 1/4 inch poly water line. Turn water back on.
Step 5: Fill and Forget
Water tank will fill up until foat valve shuts off (like a toilet float valve). Enjoy coffee, the rest of your life, without ever filling that darn tank again!
    • Trash to Treasure
      Trash to Treasure
    • Tape Contest
      Tape Contest
    • Jewelry Challenge
      Jewelry Challenge
