How to Fishtail Braid
Wanting to spice up your regular braided hairstyle? Well in this tutorial you will learn how to create an intricate-looking braid on yourself and others as well! This braid is very easy to complete and you only need a hair tie and a brush. Keep scrolling below and follow along!
Supplies:
  • Elastic hair ties
  • Hairbrush
Teacher Notes
Step 1: Brush and Dampen Hair (if Needed)
Make sure your hair is thoroughly brushed through so that is it easier to grab sections of hair. You can also dampen your hair because it helps you grab and hold onto the hair better as well as make sure there are less fly-away hairs.
Step 2: Divide Your Hair Into 2 Even Sections
Split hair evenly into 2 sections.
Step 3: Take a Thin Strand of Hair From the Left Section
Take a piece of hair about 0.5 in. thick from the outside of the left section of hair.
Step 4: Pull Left Strand of Hair to the Right Section of Hair
Take the section of hair you just grabbed and bring it to the right section of hair, combining the hair with the right section.
Step 5: Repeat Step 3 and 4 But With the Right Section of Hair
Take a strand of hair from the outside of the right section of hair and bring it over to the left section. This will now be a part of the left section.
Step 6: Tighten Hair
Tug gently on the 2 sections of hair so that your braid will be tighter and less likely to fall out as you continue to braid.
Step 7: Keep Repeating Steps 3 and 4 Alternating Each Side Until You Reach the End of Your Hair
Continue to bring small sections of hair from the left and right sections to the opposite side, alternating each time until you reach the end of your hair. Make sure to leave enough hair to tie off at the end.
Step 8: Tie Off Your Hair and Then You Are Done
You have now completed the braid!
Be the First to Share
    • Instrument Contest
      Instrument Contest
    • Make it Glow Contest
    • STEM Contest
      STEM Contest
