Introduction: How to Fix Google Play Store “No Connection- Retry” Error
Method 1:
One of the reasons for this error could be the cache of the Play store. So the easiest solution is to clear the cache. For this go to Settings > Apps and scroll to All apps section and find the “Google Play Store” app listed there. Open the app and hit clear cache button and also force stop this app.Now try opening the Google Play store again and see if the issue is fixed.
Method 2:
Check if the data and time on the device is correct. A lot of times Play store will not work properly if the date and time is not correct. This error even happens on Windows Phones as well. Once you fix the data and time, come back to Play store and check.
Method 3:
If the two steps above does not work, you need to remove your Google account and add it again. Go to Settings-> Accounts and remove your Google account and add it back. Now come back to Google Play and you might be prompted to accept the licensing terms and Play store will start working. This method might be able to fix most of the errors.
Method 4:
Try reinstalling the app or update the Play store app in case not working. For updating you might have to download the latest Play store APK file and install it by copying the file on to your device. Cross check if Google services framework is also the latest on your device.
Method 5:
If none of the methods work for you, the last method would be to reset your device. Before you do the reset make sure you take a backup of all the personal files and data.
For any tech related queries: www.techbuffy.com
