How to Glue Stuff: With a Soldering-iron
2,970
About: always had a deep connection with junk. drawn to it, magically, from childhood on. spent the nights as a boy roaming the streets and looking for trash to take back home. spent # 2 most of my allowance on the...
i love tools, but: the glue-gun is a creature i am not too crazy about. its messy, passive, wasteful, inflexible... - especially when it comes to small, tricky jobs.
so i started instead to use the good old soldering-iron to heat & apply the hotglue*.
its great because you can be much more precise and since the tip of the iron is both, heating-tool and a ´knife´, you can manipulate/apply the glue in ways you can only dream of with a glue-gun. f.e., if a spot/seam came out not as you wanted you just go back to it, reheat it, reshape it, add more glue, etc etc.
* hotglue should come in the form of thread in rolls - just like solder. different gauges would be better still. - well, i just cut down glue-sticks, to any size wished... all the way down to spaghetti-size ,,, following just a few quick pictures, the technique of application really does not need any demonstration, its all straight forward, just let your imagination go wild..... but if you got any questions etc, please aks.
Teacher Notes
Step 1: Make Hotglue Spaghetti (crash-course):
mostly there is just too much sh&it ozzing out of a traditional glue-gun... its not just a waste, it also sucks to work with.
ok, just cut down an existing stick to any shape and size that suits you (no-brainer: doesnt have to be thread-like, you can also ´grate´ it in flakes or pellets etc etc)
also, as always, many ways lead to rome: so here below just o n e quick way to cut the sticks (in this case 7mm) down to thread-like pieces.
i use a metal rule (as straight edge guide) with a box-cutter over some old card-board.
Step 2: Done
now go and glue-solder your hearts out
thanks
over&out, greetings from the mountains
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    4 Discussions
    la xerraUncle Kudzu
    Reply 1 day ago
    hi uncle, thanks to you for stopping by. greetings, grandma
    jargule
    4 weeks ago
    Doesn't this ruin the the soldering iron tip or have found a good way to clean it off afterwards?
    la xerrajargule
    Reply 27 days ago
    no.... at worst use rubbing alcohol (isopropyl), etc
    and... i make often my own tips... maybe you find that useful:
    https://www.instructables.com/id/Diy-Custom-tips-for-Soldering-iron/
    ps, thanks for posting.
