How to Install Final Cut Pro X Transitions Presets
6,360
REQUIREMENTS:
  • Apple Computer / Laptop
  • Final Cut Pro X installed
  • Browser to download desired Final Cut Pro X transition preset(s)
Teacher Notes
Step 1: Downloading Transition Presets and Finder App
After you have downloaded your desired Final Cut Pro X preset from your browser whether it be from Google Chrome, Safari, Firefox, etc. Then open up the 'Finder' application.
Step 2: In the Finder App
Once you're in the Finder application. Make your way to the 'Downloads' folder which should already be bookmarked on the left of your 'Finder' window. Once you are in the 'Downloads' folder scroll up, or down, until you find your desired transition preset. Which will most likely be in a compressed file as shown in the example image. The file is a .zip file. It can be a .rar or any other compressed format as well, so make sure to have the appropriate decompression software downloaded.
Step 3: Uncompressed Folder
Double clicked the compressed file (.zip, .rar, etc.). A uncompressed folder should appear as shown in the example image.
Step 4: Copy the Transitions Folder
Right click on the transitions folder. A drop down menu should appear. Scroll down to 'Copy' the folder onto your clipboard. We will then paste the folder into another folder in a different location on your computer.
Step 5: Home Tab
After you have copied the preset folder. Look for your "Home" bookmark as shown in the example image. Click on it to enter that bookmark structure.
Step 6: Home Tab to the Movies Folder
Once you're in the "Home" bookmark. You'll see a variety of folders with different names. Find the folder labeled "Movies". Double click to enter into that folder.
Step 7: Motion Templates Folder
Once you are in the "Movies" folder. Find the "Motion Templates" folder. Double click to enter into that folder.
Step 8: Transitions Folder
Once you are in the "Motion Templates" folder. Find the folder labeled "Transitions". Double click to enter into that folder.
Step 9: Paste New Transitions Into Transitions Folder
Now that you are in the "Transitions" folder. You will need to paste the new transition presets folder you originally copied in step 4 into this Transitions folder shown in the example image above. In-order to paste. Use this shortcut command on your keyboard. Command + V.
Step 10: New Final Cut Pro X Transitions Are Installed
Open up Final Cut Pro X. Go to the Final Cut Pro X transitions section to find your newly installed transition presets and enjoy the awesome!
Be the First to Share
    • Made with Math Contest
    • Multi-Discipline Contest
    • Robotics Contest
      Robotics Contest
    2 Discussions
    strongside39
    Question 5 months ago on Step 8
    I can’t see my transition folder in my motion template folder ,, to copy n paste new transition ,, what can I do about this??
    Welcome to Instructables. Thanks for sharing your tutorial with the community.
