How to Keep Ants Away From Your Food
About: always had a deep connection with junk. drawn to it, magically, from childhood on. spent the nights as a boy roaming the streets and looking for trash to take back home. spent # 2 most of my allowance on the...
you might live in a primitive cabin (like me), or be outdoors etc: here is how you prevent ants from building a super-highway to your food. its fast, simple, free:
Teacher Notes
Step 1: The Wonder-weapon:
a plastic bottle. just pull it out of the trash, or, better yet, pick it up as litter.
Step 2: .... Snip Snip Snip ....
cut off the top-part (use scissors, knife, teeth..)
a n d
have a piece of wire handy (although you can also use a piece of smooth wood, see more below)
Step 3: Insert
the wire (etc) gently for some (under-cut*) hole in the bottle cap
* here done with a needle, or any other sharp-pointed object... undercut, because you want a ´natural seal´ to occur
Step 4: Support
not necessarily needed, but helpful to keep the gadget upright: use a second cap (or even a disk you can cut out of plastic, etc) pushed over the wire and down into the neck of the bottle - see photo below
Step 5: Hook It, Load It
form some simple hooks on the ends of the wire (obviously cut to any size you need).
turn the gadget upright, fill it partly with water (soit will create a barrier between the wire and the bottle-top the ants cannot cross)
hang it, wherever needed (f.e. a branch, or string, etc)
the hook below takes the ´load´ (a bag with food etc)
p s,
see note above: if you dont have wire use a piece of round smooth wood > not the ends so you can attach strings
Step 6: Done
.... sorry ants.... next time.... somewhere else....
over&out
ps, work less, play more
Be the First to Share
    • Skateboard Contest
      Skateboard Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
