How to Make Air Cooler
Introduction: How to Make Air Cooler
About: I enjoy making new Instructable
Making air cooler is easy and simple project with basic tools this small air cooler can lower the temperature upto 3 to 4 degrees ,if you like this tutorial please like share and vote and if you don't understand something please watch the video.
Step 1: Things Needed
Thermocol Sheet
2 piece of 10'' x 11''
2 piece of 9'' x 11''
2 piece of 9'' x 7''
Plastic tub
Aluminium Piece 4'' x 10 ''
12v supply
12v cpu fan
Switch
Step 2:
Make a square box from the thermocol sheet by putting the bowl in center with hot glue
Cover the bottom with 10'' x 11'' piece
Step 3:
Mark the fan size on 10'' x 11'' piece and cut it out
place the fan in the hole and put hot glue around it
joint the wire with switch by 12v supply
Hot glue the connection
Step 4:
Make a hole with 5 inches round cutter
place aluminum piece making a circle and joint it with hot glue
Our air cooler is ready don't forget to vote and watch the video :)
Be the First to Share
    • Pocket-Sized Speed Challenge
    • Metalworking Contest
    • Maps Challenge
      Maps Challenge
