How to Make Beautiful Light Decoration From Plastic Bottles
About: Bobamosys stands for Bottle Based Modular Systems. It's an approach that recognizes that plastic bottles are a piece of engineering that are composed of different elements that can be processed to a new prod...
Do you have colorful plastic bottles? Hosting a party soon? Then this is the perfect project for you. It's very easy to make and you can turn used plastic bottles into something beautiful.
Teacher Notes
Step 1: Preparing the Materials
For this project you will need
  • Scissors/retractable blade
  • Plastic bottles (small bottles of around 15 oz)
  • Smaller white plastic bottles (yogurt drinks usually work well)
  • Christmas lights
Step 2: Creating Your 'Sea Gooseberry'
If you're confused as to what a sea gooseberry is and how to make them out of plastic bottles, don't worry. We made a post here on Instructables that shows the very easy steps into creating the sea gooseberries that you sea above. It is titled "How to Make Awesome Sea Gooseberries" (https://www.instructables.com/id/How-to-Make-an-Awesome-Sea-Gooseberry-From-Plastic/)
Step 3: Creating the Lantern
Once you have successfully created a sea gooseberry from a plastic bottle, take the smaller bottle and remove the label. Try to insert the smaller bottle inside the sea gooseberry. I suggest trying to fit in the neck of the smaller bottle with the neck of the larger bottle first as seen on the picture.
Step 4: Adding the Lights
Mark the smaller bottle using your retractable knife with a cross. This will the hole where you will fit the Christmas lights in. Once you've marked your bottle, you can start placing lights in each of the bottles.
Step 5: Hang It Up and Enjoy the Beauty
Once you have a bottle in each light, you can hang it up and enjoy the beauty of the decoration!
Be the First to Share
    • Art Skills Challenge
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
    audreyobscura
    2 months ago
    The lighting effect is awesome! Thanks for sharing!
