How to Make Beeswax Finish for Cutting Boards
Introduction: How to Make Beeswax Finish for Cutting Boards
About: Hi! I'm Matt and you can follow along as I [Build] new projects [Learn] new skills and [Repeat] the process. See all my projects and more at mwawoodworks.com
If you've ever made a cutting board as a gift or to sell, you've probably wondered what the best finish to use is. My answer to that is the best finish to use is the one you make yourself! Stay tuned and I'll walk you through probably the easiest finish you'll ever use and how to make it yourself.
Not only is this an easy finish to use, but its an easy finish to make. It only requires two simple ingredients. Beeswax and mineral oil. That's it! Super simple, food safe and gives your cutting board a buttery smooth finish.
Where to Follow along with my work:
Downloadable Project Plans: https://gumroad.com/mwawoodworks
My Website (full tutorials, plans, videos): https://www.mwawoodworks.com
My YouTube (all my build videos): https://www.mwawoodworks.com
My Instagram (behind the scenes stuff): https://www.mwawoodworks.com
My Pinterest (things I find inspirational) : https://www.mwawoodworks.com
Supplies:
1 lb bag Beeswax Pellets
(4) 16 oz Bottles Mineral Oil
Crock Pot or Double Boiler
Turkey Baster
1/2 Cup Measuring Cup
(20) 4 oz Tins
Teacher Notes
Step 1: Ingredients and Recipe
For the beeswax, I like to buy mine in a 1 lb bag of pellets. You can also get "chunks" or "bricks" of wax, but these pellets seem to melt much faster than those other forms do. You can get your wax locally from a bee keeper or you can buy it on the internet as I like to do.
For the mineral oil, the key is to get "pharmaceutical grade", "food grade", or "100% pure" mineral oil. Basically this is the stuff you would buy at a drug store or a grocer (or on-line). Brand isn't important as long as its 100% pure.
My recipe calls for a 4 to 1 ratio of mineral oil to wax. So I usually get four (4) 16 oz bottles of mineral oil and one (1) 1 lb bag of bees wax pellets.
Step 2: Add Ingredients to Crock
Now, you need something to heat up this mixture and there is really no better tool than a crock pot or double boiler. If its vintage 70's then even better!
Just dump in all four bottles of mineral oil first. Then add the wax pellets to the oil. The wax will settle at the bottom and will need periodic stirring to make sure it doesn't clump up at the bottom of the crock.
Step 3: Heat Up Your Mixture
Turn the crock pot to it's highest setting. You'll want this in order to melt the wax as fast as possible. On mine, there are two options "High" and "Low". I'll let you guess which one I chose...LOL
Keeping the lid on your crock pot will help the mixture heat up faster. With one or two stirrings, the wax should completely melt in about 30 minutes.
Step 4: Storing Your Wax
While you're waiting you can set up the containers you'll be storing the wax in. For me, I like using these 4oz round tins. They are a perfect size for using and for shipping if you plan on selling your mixture to others.
Now lets talk delivery system. Probably the best tool for this job is a turkey baster. You can safely deliver your mixture to the tins with little chance of spillage.
However, if you're like me and you aren't allowed to use the baster and are too cheap and lazy to buy another one for the shop, then just use a 1/2 cup measuring cup. This old reindeer measuring cup works good for me. You'll want to make sure it has a pour spout on it if at all possible again, to minimize spilling.
That reminds me, make sure to put a scrap of plywood or parchment or some other thing to prevent wax from spilling on your work surface. You'll thank me later!
Step 5: Deliver Your Wax to the Containers
Now CAREFULLY deliver the wax to the containers. PLEASE AVOID GETTING BURNED with hot wax. Keep it safe people! This recipe is good for about 20 of these 4 oz tins with just a little to spare at the end. Go back and carefully top off your containers with any remaining wax. and then let them sit for about two hours to completely cool and solidify.
Step 6: Lid Up Your Wax
Once your wax is completely cooled and hardened, you can lid them up and store them in a cool location, preferably not your shop in July if you don't have AC!
Step 7: Use Your Wax Finish
Now, to use your wax on a new cutting board, just apply a liberal amount of wax to all surfaces of the board.
Let the board sit like this for as long as possible. I like to leave them overnight. This allows the board to soak up as much of the mineral oil as it can and leaves the wax behind on the surface to solidify.
Once this happens, just use a clean cotton cloth to buff the wax to a soft glowing finish. It will feel buttery sooth and give a nice luster!
To recondition an old cutting board, just add a thin coat of the wax and buff out after a couple hours.
Step 8: THANK YOU!
I hope you found these instructions helpful! If you'd like to see more detail, check out this video where I walk step by step through the build!
If you enjoyed this tutorial and found it helpful, you can see more of my work in the following places:
My Website (full tutorials, plans, videos): https://gumroad.com/mwawoodworks
My YouTube (all my build videos): https://gumroad.com/mwawoodworks
My Instagram (behind the scenes stuff): https://gumroad.com/mwawoodworks
My Pinterest (things I find inspirational) : https://gumroad.com/mwawoodworks
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Wearables Contest
      Wearables Contest
