How to Make Bicycle Security Alarm Circuit
About: Share diy projects to those who have the same hobby with me
Hii friend,
Today I am going to make a circuit of bicycle security alarm circuit.when any body will touch bike then buzzer will activate and give sound.
Let's get started,
Teacher Notes
Step 1: Take All Components As Shown Below
Components required -
(1.) LED - 3V x1
(2.) 8-Pin IC Base x1
(3.) IC - LM555 x1
(4.) Resistor - 10K x1
(5.) Resistor - 470 ohm x1
(6.) Battery - 9V x1
(7.) Capacitor - 16V 470uf x1
(8.) Buzzer x1
(9.) Metal surface
(10.) Battery clipper x1
Step 2: Circuit Diagram
Connect all components on the PCB according to the circuit diagram.
Step 3: Solder IC Base on the PCB Board
Solder IC Base on the PCB Board and short pin-4 to pin-8 as shorted in the PCB.
Step 4: Solder 10K Resistor
Next we have to solder 10K resistor between pin-6,7 to pin-4,8 of the IC base.
Step 5: Solder 16V 470uf Capacitor
Solder 16V 470uf capacitor on the pcb board.
Solder +ve pin of capacitor to pin-2 of the IC and
-ve pin of capacitor to pin-1 of IC base.
Step 6: Solder 470 Ohm Resistor
Now solder 470 ohm resistor to pin-3.
Step 7: Solder LED
Next solder +ve leg of LED to 470 ohm resistor and
-ve leg of LED to pin-1 of the IC.
Step 8: Connect Buzzer
Solder +ve pin of buzzer to pin-3 and
-ve pin of Buzzer to pin-1 of the IC.
Step 9: Solder Metal Wire
Next solder metal wire to pin-2 of the IC.
Step 10: Solder Battery Clipper Wire
Now solder battery clipper wire to the circuit.
Solder +ve wire of Battery clipper to pin-8 of the IC and
-ve wire of Battery clipper to pin-1 of the IC as circuit diagram.
and plug in LM555 IC to it's ic base.
Step 11: Circuit Is Ready
Connect battery to the battery clipper.
Result : As you can see in the picture when I touch on the metal surface then LED is glowing and Buzzer gives sound.Like this when someone will touch on the bike then buzzer will give sound.
~ This type we can make bike security alarm circuit using LM555 IC.
If you want to make more electronic projects then follow utsource123 now.
Thank you
Be the First to Share
    • CNC Contest
      CNC Contest
    • Make it Move
      Make it Move
    • Teacher Contest
      Teacher Contest
