How to Make Diy Bird Cage
Introduction: How to Make Diy Bird Cage
About: I enjoy making new Instructable
Making cage for birds and small pets are good option as it protects them and they feel like it as there home.
Cage making is easy with some basic skills ,today I am making cage on metal using aluminium it will be sturdy and waterproof .
If you want to see it in details please see the video and vote for this tutorial as well
Supplies:
Aluminium Beams
10'' x 2
12'' x 4 for support
12''x 2 for door support
12''x 4 for under the cage net secure
16'' x 4 for under the cage net secure
16'' x 4
4.5'' x 2
10.5''x 2
Mesh Net
Aluminium sheet for bottom
Rivets
Door knob
small hinges
Superglue
Step 1: Making Rectanngles
Drill holes in the 12'' and 16'' beams place 12'' over the 16'' and tighten it with rivet making 2 rectangles one for top and one for bottom
Step 2: Giving It Support
Take 12'' beams and make holes on the edges on both sides place them under the rectangle corner and tighten it with rivet with both the structure on top and bottom making perfect rectangle box
Step 3: Door Support
over the front door section of 16'' and marking on 5.5'' and 10.5'' and drill a holes
place Place 12'' under it and tighten it with rivet making a door support
Step 4: Making Door
Take 10.5'' and 4.5'' and make rectangle same as previous method
Mark on the Door support over 3.5 and 9.5 and place small hinges and secure them with rivets
Place door on it;s position and also secure it with the rivets making the door open and close smoothly
Step 5: Covering It
Cut out the aluminium sheet same the area inside of the bottom part and place there
Put super glue on all it's edges as well
Cut out the mesh wire of all the window areas and superglue it so it just stay there while we put the same size aluminium beam over it from inside the structure and securing it with the rivets doing it all over the cage
Step 6: Giving the Cage a Knob
Mark the handle hole place and drill it out and secure the door handle with screws .
Our cage is ready for all the small birds and pets
Pets Challenge
Pets Challenge
Be the First to Share
    • Exercise Speed Challenge
    • Pocket-Sized Speed Challenge
    • Metalworking Contest
    3 Discussions
    GregoryS97
    GregoryS97
    Question 1 year ago on Step 3
    Nice project! Where can I buy the aluminum beams?
    Umair Workshop
    Umair Workshop
    Answer 1 year ago
    Thank you , it can be found in metal hardware shop.
