How to Make Clap Switch | DIY Project | Home Automation | Electronics Projects
About: This is Electronic Project Forum which aims to help new members to build easy D I Y ( Do It Yourself ) Electronic Projects
#CircuitDIY
This video tutorial is SPONSORED by PCBGOGO Services. They are providing a quality PCB's for Under 5$ Only first register from the link below and
Upload your Gerber file / Eagle design That's it....
►► https://www.pcbgogo.com/
Hello , Today in this video tutorial i am going to show you Step By Step
How to make a simple clap switch circuit using cd4017 ic and 5volt relay
This Electronic Project is Very Simple Easy and DIY (Do It Yourself)
❖ Please Subscribe / Like Facebook Page ❖
https://www.youtube.com/channel/UCi6ZqREHDIx2xLrC...
https://www.facebook.com/Circuit-DIY-122206971927...
You Will Find Full Project Description and All Useful Material Including
• Circuit Diagram / Schematic • Hardware / Component List • Code • Datasheet • Pin Configuration Etc
AT ► xxxxxxxxxxxxxxxxxxxxxxxxx
Circuit Diagram ► https://www.file-up.org/ebp9bihsao8q
Gerber File ► https://www.file-up.org/qamg05vvappw
Thanks for Watching It.
↪ For Any Difficulty Please Comment Below
Step 1: Useful Material
❖ Hardware Required ❖
  • ► CD4017 IC with Base
  • ► 5v Regulator
  • ► 5v Relay
  • ► Condensor Mic
  • ► Transistors BC547 2x
  • ► LED 2x
  • ► 1k Ohm Resistor 3x
  • ► 22k Ohm Resistor
  • ► 470 Ohm Resistor
  • ► 9V Battery with Clip
Step 2: Useful Steps
  • STEP # 1 ( Solder Relay )
  • STEP # 2 ( Solder IC Base )
  • STEP # 3 ( Solder 5v Regulator )
  • STEP # 4 ( Solder LED's & Diode )
  • STEP # 5 ( Solder Transistor's )
  • STEP # 6 ( Solder Resistor's )
  • STEP # 7 ( Solder Mic )
  • STEP # 8 ( Solder Input and Output Connectors )
  • STEP # 9 ( Cut All Extra Wires)
  • STEP # 10 ( Connect IC and Power Up Circuit )
    • Sweet Treats Challenge
    • Warm and Fuzzy Contest
    • Epilog X Contest
      Epilog X Contest
