How to Make Concrete Tree Stump
299
About: My Small Workshop. To develop and build on the ideas that I have.
I need a Tree stump for placing a plant pot. But i love trees So I won't cut it.
I have an idea to make a tree stump from concrete. And I will make it for you to watch.
Teacher Notes
Step 1: Materials and Equipment
1. Newspaper
2. Sand
3. Wire mesh
4. Brick trowel
5.Mortar cement
6. Mortar mixing bucket
7. broom
8. wood stalk
9. Wire cut scissors
10.Cement color
Step 2: Wire Cutting
1.Cut the wire mesh to the desired size.
2.Make a cylinder. By using the wire.
Step 3: Make a Mold
1.Put newspaper in to prevent sand getting off.
2.Pour the sand into it.
3.Closed wire mesh
Step 4: Mixing Mortar
Mix cement and water in a ratio of 2: 1, 2 parts mortar, 1 part water. And mix well.
Step 5: Plastering Around Roughly
Plastered rough
Step 6: Texture Decoration
Draw textures like old wood.By using a wood sliver 3-4 pieces to draw the line.Then decorated with a trowel.
When finished Use a broom to sweep away debris, concrete.
Step 7: Paint
  1. Use the yellow, orange and green spray paint to make the color of the wood core.
  2. Use paint for fiber cement To make it look like a bark
Step 8: Finally
Wait for the color to dry. Pour out sand. And can be used to decorate the garden.
You can watch the step-by-step video. Have fun with landscaping.
Stone Concrete and Cement Contest
Be the First to Share
    • CNC Contest
      CNC Contest
    • Teacher Contest
      Teacher Contest
    • Maps Challenge
      Maps Challenge
    4 Discussions
    AussieAlf
    25 days ago
    Great job Patsakorn, quite realistic. I would probably bury it a little in the soil to hide the bottom line.
    Next job is to fix that bench properly before you come a cropper.
    Cheers...
